Switch For Wall Outlet Dims Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 01:21 PM   #1
Switch for wall outlet dims lights
Recent change the switch and outlet. Now th outlet dims the lamp when turned off.. The switch has two black. The outlet has one black and two white. A black and white on one side and one white on the other. This was changed by my brother and i did not see th original wiring.
Jg2c is offline   Reply With Quote
Old 08-12-2012, 01:45 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Take some pictures, because I dont believe what you are saying.
Old 08-12-2012, 01:50 PM   #3
joed's Avatar
Rewards Points: 11,590
Tell us all the cables in the receptacle box, in the switch box and in the light box. What did the switch control? The light fixture or half the receptacle? If half the receptacle did he remove the tab on the side of the receptacle.
Old 08-12-2012, 01:58 PM   #4
E2 Electrician
The switch is opening and closing a neutral connection... take some pics of the switch box and receptacle box...
Old 08-12-2012, 03:09 PM   #5
Exclamation
pics
Switch only controls the outlet . No over head light in room.
1 receptacle box
2 Outlet
3 Switch
Switch for wall outlet dims lights-img_0292b.jpg   Switch for wall outlet dims lights-img_0291b.jpg   Switch for wall outlet dims lights-img_0293b.jpg
Old 08-12-2012, 04:42 PM   #6
E2 Electrician
You need to pull out the wires in the receptacle box, The splice is not right.
Old 08-12-2012, 07:36 PM   #7
i would guess the whites on the outlet got switched in the process of changing the outlet.
on the switch it wouldn't matter which wire went where but on the outlet it would. was only half of the outlet switched? if so was the tab on the hot side broken out between the screws?
Old 08-12-2012, 07:38 PM   #8
E2 Electrician
Would be a dead short if that was the case.
Converting switched outlet to unswitched.. Blivit Electrical 8 07-11-2011 08:07 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
How do I connect one switch to 3 lights? Dorkus Electrical 9 09-27-2009 11:08 PM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 11:11 AM
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 09:09 PM
