Switch Trips Breaker................. - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 07:13 AM   #1
Rewards Points: 154
Switch trips breaker.................
We just had our bathroom remodeled and one thing we had them do is install a combo heat lamp vent fan. The wall plate for this unit has 5 time settings for lamp along with the on / off switch for the fan. on the same wall is a 2 plug outlet with the standard built in circut breaker. I would say 1 out of every 6 or 7 times when you turn off the fan, the circut outlet blows, and it has to be reset, we had the general out and he is puzzled. so I thought I would throw this out to you pro's for feedback. thanks a much!!!
turbomangt is offline   Reply With Quote
Old 09-16-2010, 07:38 AM   #2
DIY staff
Rewards Points: 7,174
What you are describing sounds like a GCFI (ground fault outlet) tripping--not a circuit breaker.
One of the electricians will chime in soon--Typically the heater/fan/light require their own circuit----------Mike----
Old 09-16-2010, 07:43 AM   #3
Rewards Points: 154
Yes, I stand corrected, GCFI outlet is right now that I remember that term. Is that unusual since we have not even used the heater yet? I would not think the fan alone would trip the GCFI? the bath room is on its own circut not shared with any other rooms in the house. I was thinking it might be a defective switch?
Old 09-16-2010, 08:46 AM   #4
joed's Avatar
Rewards Points: 12,892
The fan is a motor. Motors can trip GFCI's. Can the fan be moved to the LINE side of the GFCI?
Old 09-16-2010, 08:49 AM   #5
Rewards Points: 154
NOt sure what u mean? Not an electrician, just tell me what I should advise my contractor,can this be done with little problems or?? so was it wired incorrectly?
Old 09-16-2010, 10:18 AM   #6
DIY staff
What he is suggesting is quite simple---The GCFI outlet can protect fixtures 'down line' (your fan)LOAD
Or the power can pass through the unit with out being protected--LINE
---Mike---
Old 09-16-2010, 10:21 AM   #7
Rewards Points: 154
Hey MIke, great when you come over you can look at it for me!!!!!!!! will call you later today.
The Following User Says Thank You to turbomangt For This Useful Post:
oh'mike (09-16-2010)
Old 09-19-2010, 12:01 PM   #8
Rewards Points: 154
Just need to send out a special thank you to OH'Mike, all you guys are awesome for helping us novices and when I noticed Mike was not far from me I asked him to bid on a bathrom job, he showed up on time, was professional, I could tell he was well qualified, I figured while he was here I'd ask him to look at my wall switch that was tripping, he said let me open it up and have a look, in less than 5 minutes, problem solved, no more issues with tripping, it was wired wrong. I can't say enough about Mike going the extra mile, It was great meeting him, if I can afford him, he would be the guy for my bath for sure!!!! ok Mike this should be worth a nice discount right? LOL!!!!!!!!!!!!!!!!!!!!!!!!!!:y es:
oh'mike (09-19-2010)
Old 09-19-2010, 12:21 PM   #9
" Euro " electrician
frenchelectrican's Avatar
I am glad that Oh'mike did came out and help you that is very nice of him to do that for you.
Merci.
Marc
New pool pump trips breaker?! New home owner needs advice. KenR7A Electrical 22 01-05-2011 09:42 AM
Circuit Breaker that trips slowly dmoore Electrical 15 09-07-2010 06:25 PM
New Air Conditioner trips breaker Cano Electrical 4 07-11-2010 10:29 AM
Breaker Tripping Jeridmar6 Electrical 15 07-10-2010 08:20 PM
How to test that a breaker trips on short BradSG Electrical 13 07-08-2010 08:45 AM
