Switch Trips Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2008, 02:48 PM   #1
Switch trips Breaker
Hi,
Working on a home I purchased last year...one of the rooms had a ceiling fan that did not work properly and also my wife didn't like its looks (so down and out it went. Before taking it down I noticed that it was controlled by only one switch however with the switch on, both the lights and the fan were either both on or both off and a humming ground noise was ever present. Since I was about to replace it, didn't give much thought and took it down.
After removing the old fan, I went on to install a brand new one. The wires hanging were the usual black, white and ground. Hooked up the black to black, white to white, green to ground and turning the switch on tripped the breaker that handled this room plus the hallway and adjacent bathroom lights. I opted to disconnect the new fan entirely and lo and behold, turning the switch on is tripping the breaker even if the wires are not connected to anything. Any suggestions at what possibly could be the problem and how to check if the switch has gone bad?
Thanks,
G
pvrio is offline   Reply With Quote
Old 09-21-2008, 02:51 PM   #2
Electrician
Originally Posted by pvrio View Post
Hi,
Thanks,
G
Its somthing you did. Is the wiring old? What else did you touch?
chris75 is offline   Reply With Quote
Old 09-21-2008, 03:32 PM   #3
I had to replace the ceiling electrical box as the one that was up there wasn't designed to hold a fan in the first place. I am starting to think that while putting the new electrical box I somehow chewed the wire up in there. The wires are really not that old, the house was built in 1989. I took the switch off the circuit and the problem persists so now I am prety darn sure it is a wiring issue...comments welcome.
Old 09-21-2008, 04:00 PM   #4
Electrician
Um, yeah, you created a short, gonna have to take that it apart and find the problem. Which box did you install? The one with expandable arms?
Old 09-21-2008, 04:53 PM   #5
Take a look at the screws that hold the fan bracket.
Homeowners are notorious for screwing them thru the wires.
220/221 is offline   Reply With Quote
New pool pump trips breaker?! New home owner needs advice. KenR7A Electrical 22 01-05-2011 09:42 AM
Moved ceiling light in bedroom to center, now trips breaker blthomas Electrical 18 01-24-2008 04:29 PM
20 Amp Breaker only trips once in a while panhandlion Electrical 14 11-26-2007 08:36 PM
Main Breaker Trips Repeatedly kkf Electrical 7 06-18-2007 04:31 PM
Light Switch Keeps Tripping Breaker jackiesmom Electrical 23 05-24-2007 02:27 PM
