Switch Replacement - Lights Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 03:05 PM   #1
switch replacement - lights not working
I recently replaced some of my home’s light switches and outlets… some dimmers, 3 and 4-ways, a few GFCIs so nothing overly complicated.
After turning the circuit breakers back on, the overhead light in a separate but adjoining room does not work. It is controlled by two 3-way switches in that room only, neither of which were replaced nor did I replace any of the duplex outlets in that room. Any idea what I could have done wrong? thanks
noviceDIYr is offline   Reply With Quote
Old 11-30-2010, 03:18 PM   #2
Failed bulb?
It is possible that some of the devices you changed fed power to the now-disfunctional light. Perhaps a loose or missing connection in one of those boxes?
oberkc is offline   Reply With Quote
Old 11-30-2010, 03:30 PM   #3
had ruled out a failed bulb since each one (chandelier) was working just a few hours prior.
will recheck the connections... I think the screw connections are pretty tight but maybe one of the backwired ones is loose. thanks.
Old 11-30-2010, 04:32 PM   #4
Unlikely there are multiple bulb failures, I agree.
If you don't have a voltmeter, go get one. Such a tool is practically a necessity if you plan to do electric work, even projects such as this which are not overly complicated. Without one, you are troubleshooting by trial-and-error. This is no way to work.
3-way switches, lights, and a photoelectric switch. Your thoughts? Fox Electrical 7 11-23-2010 11:08 AM
Dimmer switch is warm even when lights are off! gonzo Electrical 17 05-25-2010 08:10 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
2 lights 1 switch lymantuttle Electrical 10 01-04-2010 06:49 PM
1 switch, 3 lights? help? bexnfx Electrical 5 09-12-2005 03:17 PM
