Switch And Receptacle In Same Box - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 11:01 AM   #1
Switch and Receptacle in same box
In my bathroom I have a box with a switch for a light and a receptacle side by side. I need to have constant power to the recepatcle and use the switch just to turn the light off and on. I have 2 sets of black and white wires coming in to the box and a black and white for the light fixture plus the ground wire for all. Is it possible to do?
andog1117 is offline   Reply With Quote
Old 09-10-2012, 11:56 AM   #2
how is it wired now?
how did it work before?
Old 09-10-2012, 12:54 PM   #3
Rewards Points: 2,516
So you have 3 cables coming into the box, each cable with a black, white and ground?
hammerlane is offline   Reply With Quote
Old 09-10-2012, 01:14 PM   #4
you provided minimal info so see if this fits:
Note: grounds not shown for ease of drawing
Old 09-11-2012, 12:38 PM   #5
Yes there are 3 cables coming into the box all with black,white and ground. The diagram you have is missing 1 set of wires
Old 09-11-2012, 02:14 PM   #6
Is anything connected now? If so a picture or a drawing would help us sort it out.
NHtransplant is offline   Reply With Quote
Old 09-11-2012, 04:41 PM   #7
This diagram shows how I did it but I took everything apart.
Switch and Receptacle in same box-30635d1272585839-how-do-wire-light-switch-receptacle-same-box-swithc-wirenuts.jpg
Old 09-11-2012, 04:46 PM   #8
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Andog, your diagram looks correct.
John
jrclen is offline   Reply With Quote
Old 09-12-2012, 12:18 PM   #9
So if it is wired the way the diagram says then there should be constant power to the receptacle when the light switch is switched off?
Old 09-12-2012, 12:26 PM   #10
Licensed electrician
Rewards Points: 1,296
There should be power to the receptacle with the switch oof if wired as shown.
Did you install GFI protection for the receptacles?
Old 09-12-2012, 12:29 PM   #11
There was not one there before but I had to purchase one because it is the bathroom. It is a an old place and there are no GFIs in the kitchen or bathroom. Are they wired the same way?
Old 09-12-2012, 12:31 PM   #12
Electrical Contractor
jbfan's Avatar
Rewards Points: 256
That is correct.
The Following User Says Thank You to jbfan For This Useful Post:
andog1117 (09-12-2012)
Old 09-12-2012, 12:42 PM   #13
Thank you very much
Old 09-12-2012, 01:52 PM   #14
You will use the LINE side terminals on the GFI for the power in. Any downstream receptacles would be off the LOAD side.
Old 09-12-2012, 05:56 PM   #15
Got it. thank you all
3 way switch to split receptacle Jrhenry24 Electrical 13 07-31-2012 10:59 PM
Electrical power disappeared from switch to receptacle craighank Electrical 3 02-19-2012 02:06 PM
Adding new receptacle and switch 8888 Electrical 16 02-07-2012 11:27 PM
Switched Outlet, Power into the switch then to switched receptacle ryanwake Electrical 1 01-23-2011 01:52 PM
Wiring receptacle > switch > motion sensor lights Van Home Electrical 11 08-10-2010 12:27 AM
