-   -   Switch and Receptacle in same box (http://www.diychatroom.com/f18/switch-receptacle-same-box-156397/)
andog1117 09-10-2012 11:01 AM
In my bathroom I have a box with a switch for a light and a receptacle side by side. I need to have constant power to the recepatcle and use the switch just to turn the light off and on. I have 2 sets of black and white wires coming in to the box and a black and white for the light fixture plus the ground wire for all. Is it possible to do?
DannyT 09-10-2012 11:56 AM
how is it wired now?
how did it work before?
hammerlane 09-10-2012 12:54 PM
So you have 3 cables coming into the box, each cable with a black, white and ground?
hammerlane 09-10-2012 01:14 PM
1 Attachment(s)
you provided minimal info so see if this fits:
Note: grounds not shown for ease of drawing
andog1117 09-11-2012 12:38 PM
Yes there are 3 cables coming into the box all with black,white and ground. The diagram you have is missing 1 set of wires
NHtransplant 09-11-2012 02:14 PM
Is anything connected now? If so a picture or a drawing would help us sort it out.
andog1117 09-11-2012 04:41 PM
1 Attachment(s)
This diagram shows how I did it but I took everything apart.
jrclen 09-11-2012 04:46 PM
Andog, your diagram looks correct.
andog1117 09-12-2012 12:18 PM
So if it is wired the way the diagram says then there should be constant power to the receptacle when the light switch is switched off?
Jim Port 09-12-2012 12:26 PM
There should be power to the receptacle with the switch oof if wired as shown.
Did you install GFI protection for the receptacles?
andog1117 09-12-2012 12:29 PM
There was not one there before but I had to purchase one because it is the bathroom. It is a an old place and there are no GFIs in the kitchen or bathroom. Are they wired the same way?
jbfan 09-12-2012 12:31 PM
That is correct.
andog1117 09-12-2012 12:42 PM
Thank you very much
Jim Port 09-12-2012 01:52 PM
You will use the LINE side terminals on the GFI for the power in. Any downstream receptacles would be off the LOAD side.
andog1117 09-12-2012 05:56 PM
Got it. thank you all
