Switch/receptacle Height - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2007, 10:38 PM   #1
switch/receptacle height
what is the mounting height for switches and receptacles (from the floor) in a bedroom?also when running my wires to and from each receptacle how high from the floor should i run them through the studs?
whseddon is offline   Reply With Quote
Old 04-22-2007, 11:06 PM   #2
Electrician
Rewards Points: 802
For switches 50-54" is good, lower if it is for handicap people. 12" for plugs along the wall.
If this is in your current home I would measure a few other plugs and switches in your house and make them all the same.
Darren
darren is offline   Reply With Quote
Old 04-24-2007, 05:47 PM   #3
joed's Avatar
Rewards Points: 13,740
There is no code for this height. Make them the same as the rest of the house so they look the same.
minimum window height mt232 Building & Construction 7 03-24-2007 01:10 AM
raising ceiling height during remodel marks Building & Construction 1 10-04-2006 01:58 PM
Joining laminate floors of different height. flyingmachine Flooring 5 09-13-2006 08:59 PM
flange height farrington135 Plumbing 1 04-20-2006 05:01 PM
Wall height Puppy Building & Construction 5 01-23-2006 05:00 PM
