Switch / Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2008, 11:55 AM   #1
Switch / Receptacle
Hi, I am replacing a Single-Pole Switch / Receptacle. The new switch has 5 screws:
Side 1: green, silver
Side 2: brass, black, black
The outlet box has 3 wires, two beige and one black. I connected black to green and beige to brass and black but only light switch works. Beige to black and black has power but no switch. Thanks in advance.
Mike
mikbro is offline   Reply With Quote
Old 10-31-2008, 12:03 PM   #2
Rewards Points: 83
Huh? So this is a two gang box with a switch and a receptacle? Any chance this is a knob and tube setup? And you ONLY have 3 wires into the box? What does the switch control? Is the switch supposed to switch the receptacle?
Also, it sounds like you have a 4 way switch, not a single pole. Therefore likely one wire is neutral, one is common, one is hot. Assuming this, you would pig tail the receptacle to the hot/neutral and wire the switch to the proper terminals likely hot, neutral, and common. However, with out more info, I am guessing based on your description.
Bubbagump is offline   Reply With Quote
Old 10-31-2008, 12:30 PM   #3
Hi thanks for quick reply.
Switch turns on light.
It's a Deco Switch And Recept #7730W-SP similar to this one.
Old 10-31-2008, 12:33 PM   #4
Rewards Points: 83
Ok, this makes way more sense.The black (hot) wire from the power connects to one of the dark screws that are tabbed together. The white (neutral) wire from the power is pigtailed together with the white (neutral) wire from the light and connects to the light colored screw. The black (hot) wire from the light connects to the separate dark screw.
Old 10-31-2008, 12:37 PM   #5
Licensed Pro
Mike
Typical convention would be:
Green or bare wire to green screw
neutral (white) wire to silver screw
constant hot (black) wire to black screw
switched hot (black or red) wire to brass screw
But since your wire colors don't exactly match, you will have to determine which is hot, neutral, and switched hot.
How was the previous switch wired?
Old 10-31-2008, 12:57 PM   #6
joed's Avatar
Rewards Points: 12,924
You must use aGFCI device or have a GFCI breaker. This box appears to not have any grounds.
Old 10-31-2008, 01:03 PM   #7
Rewards Points: 83
Not necessarily... is the box metal or have BX coming in? You may simply be able to use a ground clip assuming there is a good path to ground somewhere.
Old 10-31-2008, 01:11 PM   #8
Previous switch was a Leviton NOM057.
Side 1: dark, silver
Side 2: brass, dark, dark
Two beige went onto the side 1 dark and side 2 dark and neutral on the silver. I tried that connection but only power works. No metal box.
Old 10-31-2008, 01:11 PM   #9
You need to identify your hot and neutral wires. You need a tester of some sort. If you try and guess you will at some point cause a dead short and trip the breaker/blow the fuse.
Beige is not really a color we use.
The hot wire will go on the right hand side. It will feed the recep and the switch via the jumper between the two screws.
The neutral wire will go on the lower left side (silver screw). It goes to the left slot on the recep.
The switch leg will go on the left side of the switch. The recep pictured looks like a 3way sw because it appears to have two terminals on the left side. A sp sw would only have one.
220/221 is offline   Reply With Quote
Old 10-31-2008, 01:13 PM   #10
Rewards Points: 83
I have a feeling the "beige" is is just an old white neutral wire. But yeah, you must get a voltage detector and find the hot. You don't want to be guessing when it comes to electricity.
Old 10-31-2008, 01:28 PM   #11
That's what I was thinking but he has two of them.
The other is may be the switch leg or????
If he just guesses, there's gonna be sparks.
Old 10-31-2008, 04:15 PM   #12
Got connections to work:
Green or bare wire to green screw (no wire)
neutral (white) wire to silver screw (black)
constant hot (black) wire to black screw (beige)
switched hot (black or red) wire to brass screw (beige)
Thanks for all help.
Adding a Hot Receptacle to a 3-Way Switch rtyui2 Electrical 11 11-21-2007 08:08 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
15 amp switch/ receptacle on 20 amp line redline Electrical 2 04-06-2006 02:00 PM
