Switch Positioning - Electrical - DIY Chatroom Home Improvement Forum
Old 02-05-2004, 10:41 PM   #1
Guest
Guest
Posts: n/a
Question
Switch positioning
Just me again...
When a door opens out (that is, into the room from which you are entering the next), is there a "standard" for which side of the hinge switches should be placed in the room that you are entering? I can understand that if the door swings in the switch should be away from the hinges, but I can't see any advantage for positioning the switch when the door swings out.
Once again...thanks in advance for your help!
Old 02-07-2004, 10:36 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
IMO for any single hinged door the switch should be on the latch side.
Center latched french doors are a different story, there is no latch side. :p
Speedy Petey is online now   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 08:47 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
