-   -   Switch positioning (http://www.diychatroom.com/f18/switch-positioning-82/)
Bob C 02-05-2004 10:41 PM
Switch positioning
Just me again...
When a door opens out (that is, into the room from which you are entering the next), is there a "standard" for which side of the hinge switches should be placed in the room that you are entering? I can understand that if the door swings in the switch should be away from the hinges, but I can't see any advantage for positioning the switch when the door swings out.
Once again...thanks in advance for your help!
Speedy Petey 02-07-2004 10:36 PM
IMO for any single hinged door the switch should be on the latch side.
Center latched french doors are a different story, there is no latch side. :p
