Switch Plate Covers - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 09:03 AM   #1
Rewards Points: 150
switch plate covers
I know well about oversize switch plate covers as I have cut out and replaced most of the boxes in my plaster walls. ( I think they'll go away the next time we repaint and do a little plaster repair)
I was wondering if there is such a thing as a somewhat deeper cover to go over a box that sits slightly proud from the wall?
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 01-24-2010, 07:33 PM   #2
firehawkmph's Avatar
Rewards Points: 1,902
Handy,
What kind of boxes do you have? If they are bakolite (spelling?) or plastic, you could stick a rubber sleeve sander in a drill and grind the edge down to flush.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-25-2010, 08:09 AM   #3
Licensed electrician
Rewards Points: 1,788
The Trademaster series of plates from Pass and Seymour/Legrand are deeper than a normal plate and should help your situation.
Did you remove the ears from the devices so they will drop into the recess of the old work tab?
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
