Switch Plate Cover Screw Bottoms Out? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 04:26 PM   #1
Rewards Points: 1,654
Switch plate cover screw bottoms out?
I have a handy box with a GFCI receptacle and once I mounted the receptacle and put the switch plate on the really short screw won't catch for some reason. I have some slightly longer ones and those caught but bottom out when they hit the metal ear of the handy box.
What is the solution? Drill a hole in the ear to let the screw through?
miamicuse is offline   Reply With Quote
Old 07-22-2012, 04:56 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I just cut the 6-32 plate screw... this happens often with a gfci is installed with a tile backslash.
Old 07-22-2012, 05:01 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Use the 1/4 X 6-32 screws I know they are short but if done right they will catch it otherwise get 3/8 inch screws that is next length you can use.
Did you any chance you used the cover screws that provived from the GFCI device out of the box or package ??
Merci,
Marc
Old 07-22-2012, 05:06 PM   #4
Electrical Contractor
kbsparky's Avatar
Either ONE of these options:
1) Cut the screw really short. If that doesn't work, then ...
2) Drill and tap out the ear(s) of the box, so the screw goes in further allowing the plate to be tight against the wall.... OR
3) Don't use a "handy box" for your GFCI outlets.
-KB
How to rewire outlet controlled by light switch? BuckyGunts Electrical 30 04-20-2012 02:18 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
How to choose light switch styles (for 2 and 3 gangs) jelly Electrical 2 06-08-2008 01:52 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
