Switch And Panel Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 06:29 PM   #1
Rewards Points: 16
switch and panel replacement
My plan is to:
A: Replace the old knife blade switch, but what do i replace it with? Do I need to have a switch there, or can I just run the cable directly from the meter to the new panel (about 75')
B: From the new switch, run new 4wire 2-2-2-4 alum ser cable from the garage to another building where I am going to install a new panel. Would that new panel be considered a sub panel or main panel?
mikec205 is offline   Reply With Quote
Old 02-09-2012, 06:53 PM   #2
Rewards Points: 14,312
With wiring that old and by the questions your asking you really need to call a real electrition to come look this over and do it for you.
Something that old will need all new wires from the pole, new panel and all new wires.
mikec205 (02-09-2012)
Old 02-09-2012, 09:34 PM   #3
joed's Avatar
Rewards Points: 13,740
You need a disconnect as close as possible to where the power feed cable enters the house. 75' away is too far. You need a disconnect. You can get a meter pan with a disconnect in it. Then you won't need the disconnect inside.
The Following 2 Users Say Thank You to joed For This Useful Post:
mikec205 (02-09-2012), plummen (02-09-2012)
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Indoor Safety Switch Between Meter and Panel silvajus Electrical 5 01-30-2012 07:46 AM
3 Way Light Switch Replacement is kicking my a**! PokerMunkee Electrical 8 08-30-2010 04:08 PM
Adding a Sub Panel for Transfer Switch dcopps Electrical 27 08-24-2009 10:36 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
