Switch/outlet - Remote Control Devices? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-15-2009, 04:07 PM   #1
Switch/outlet - remote control devices?
The wall switch in my bedroom controls one outlet. Unfortunately, it isn't in a good location for a lamp. I believe there are devices that I can plug into this outlet (and another outlet) that will then allow the second outlet to be controlled remotely.
So, right now, the switch controls outlet A.
If these devices actually exist, this is how I think they would work.
I would plug a remote control device into outlet A. I would then plug a second device into outlet B and plug the lamp into this device. When I use the switch, the device in outlet A is activated and sends a signal to the device in outlet B. When this device receives the signal, it powers on the lamp.
Has anyone heard of this and if so, what are the devices called?
Thanks and Merry Christmas !
ccjr019 is offline   Reply With Quote
Old 12-15-2009, 08:40 PM   #2
Look at x-10 or SmartHome devices.
You will change the switch and install a compatable receptacle in whatever location you choose.
220/221 is offline   Reply With Quote
Old 12-16-2009, 08:58 AM   #3
Thanks - that's what I was looking for - EOM
outlet , switch
ceiling fan remote wall control wiring akchris Electrical 6 12-15-2009 06:37 PM
AprilAire - Humidity Control Remote Mounting AndrewF HVAC 12 02-20-2009 10:35 AM
dual Remote control deck hand Home Theater 5 01-31-2009 04:53 PM
UPS powering remote devices using house wiring MusicMan_234 Electrical 16 01-07-2009 06:56 PM
Silly problem with TV remote control proofer Home Theater 8 09-24-2008 07:27 AM
