Switch-Outlet-fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 04:23 PM   #1
Hey all,
I'm a pretty avid DIY'er, but I have encountered a problem re-wiring a switch to outlet to fixture. Actually a switch to outlet to outlet to lighting fixture. I removed the old outlet (did not draw a diagram or take a picture) and just cut and placed a new one it. The question or problem I have is that I have a feed wire (coming in from the first outlet to the second) with black/white/red and another coming in from the fixture with just black and white. How is the outlet wired? I'm stumped.
I thought it was white and black coming in mounted to the outlet, and the red wire used as the traveler to the fixtures black wire. Use the fixtures white wire and mount it on the outlet and pigtail the fixtues black with the red. I'm lost.
Any suggestions would be great..
Thanks-first time user.
jackjohnson1157 is offline   Reply With Quote
Old 11-23-2008, 05:02 PM   #2
Most likely the red is being used for the light. The black would have been a constant hot to feed the receptacle. Take off the switch plate cover and see if one of the wires connected to the brass screws is red. If so connect the red and the black at the second outlet.
jerryh3 is offline   Reply With Quote
Old 11-23-2008, 05:11 PM   #3
Thanks for the reply. Just the only problem is that the wiring behind the light switch is that old cord wiring. A newer black wire is pig tailed to the other light witches in the box, with the old wire coming in too. It all worked before I pulled off the old outlet. I just forgot to look at the set- up.....
Old 11-23-2008, 09:34 PM   #4
joed's Avatar
Rewards Points: 13,308
If this worked before the connect the black to the gold screws on the receptacles. Connect the whites to the silver screws on the receptacles. Connect the reds to each other and to the black from the fixture at the last receptacle.
Old 11-24-2008, 10:06 AM   #5
There is only one red wire coming from the source going out to the second outlet. I do not have a second red wire to connect it too.
1 receptacle - 2 wires coming to it.
1 wire has black/white/red and the other has white and black.......
Old 11-24-2008, 10:10 AM   #6
joed's Avatar
In your first post you said there was two receptacles. Let me clarify the wiring from above. The reds connect to each other in the mid point receptacle and to the black from the fixture at the second receptacle.
Please clarify the setup and cables in each box.
Old 11-24-2008, 02:34 PM   #7
Here is a picture of the outlet with the wire on the left originating from the source and the wire on the right going out to the high-hats. I just can't get the right connection through the outlet for the high-hats to work with the switch.
Old 11-24-2008, 02:37 PM   #8
Here is the view into the switch box. Just one old black wire pig-tailed with the other switches and a newer black wire coming in.
Old 11-24-2008, 02:38 PM   #9
joed's Avatar
Where does the red wire in the back left connect on the switch box?
Last edited by joed; 11-24-2008 at 02:39 PM. Reason: you posted another picture while i was posting
Old 11-24-2008, 02:39 PM   #10
Here is a view from under. Those are the two high hats being powered.
Old 11-24-2008, 02:41 PM   #11
a photo of the other outlet, I believe is involved. Now their is no red wire attached behind this outlet.
Old 11-24-2008, 02:42 PM   #12
its connected to the other switch. That works my exterior lights. With the timer on the right.
Old 11-24-2008, 02:45 PM   #13
Those two wires you see coming out of the switch box are the only ones used for the high-hats. Man this sucks.
Old 11-24-2008, 02:46 PM   #14
joed's Avatar
It seems that three wire cable may not go to the switch box as suspected. We need to know where it actually goes and what it is connected to.
Old 11-24-2008, 04:06 PM   #15
Fixed... Thanks
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 08:08 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 06:11 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
