Switch Outlet Combination - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2013, 09:23 AM   #1
switch outlet combination
In my bathroom I have a switch and outlet combination. The switch controlled an overhead light. The outlet is a 120 volt outlet receptacle. The switch went bad. I bought a new switch outlet combination. A person learning the profession replaced the switch outlet combination. From all outward appearances it looked like she did a good job. The switch controlled the overhead light. But I noticed that the switch controlled the light and the outlet. The only way I could get 120 volts on the outlet was to turn the switch to the on position. The fin was intact and there were 3 cables. I don't remember if this was wired like this before. The inside of the cardboard box the switch outlet came in had two diagrams depicting two ways to wire it. One said separate feed break off the fin. It showed the switch controlling the light independent of the outlet. The outlet according to the diagram always had 120 volts. It showed the L cable going to one side of the switch and a cable connecting to the opposte terminal I assume going to the light. It showed anothe pair of cables going to the bottom terminal and another cable going to the opposite terminal indicating 120 volts always across the outlet. A total of 4 cables. I like it this way because I can always have my phone and my toothbrush charged. The second diagram said common feed fin intact, power outlet for grounded applications. It showed first the fin intact. It had 3 cables. One L cable going to the top terminal. One terminal going to the oposite terminal which was common to an unused terminal and the 3rd cable I assume was the return. My guestions: (1) What is meant by "Power outlet for grounded applications?" (2) Is there any elestrical code that would prevent me wiring it so that I have the switch that controls the light independent from the outlet where the outlet alwasys has 120 volts or in other words have the so called "Separate feed?"
phill1 is offline   Reply With Quote
Old 11-09-2013, 09:32 AM   #2
joed's Avatar
Rewards Points: 12,018
There is no code issue with having the receptacle always on.
Old 11-09-2013, 09:36 AM   #3
Thanks , You answered one question. But what is meant by "Power outlet for grounded application?"
Old 11-09-2013, 09:45 AM   #4
An old Tradesmen
Rewards Points: 6,576
Moved to Electrical forum.
The Following User Says Thank You to beenthere For This Useful Post:
phill1 (11-09-2013)
Old 11-09-2013, 09:57 AM   #5
Master Electrician
Rewards Points: 3,770
The receptacle must be GFCI protected to be code compliant.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
phill1 (11-09-2013)
Electric outlet / light on same switch Fieldy1123 Electrical 17 10-06-2012 04:26 PM
Removing an end of the line outlet from the light switch lovetobuild Electrical 13 09-02-2012 01:07 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
Combination switch and outlet 44070dart Electrical 4 05-03-2010 08:00 PM
