Old 12-11-2009, 03:38 PM   #1
Switch outlet in bathroom
We have had a combination switch and outlet in our bathroom for years. Thr outlet will work only when the switch is in an off position. I have looked at the wiring and found the black hot wire connected to the brass screw on one side and the white wire connected to the other side with a small wire connecting the two screws on the white wire side. I would like the outlet to work when the switch is on or off. I have tried a new combination switch with the same results. There are only two wires in the box,a black and a white.
odale is offline   Reply With Quote
Old 12-11-2009, 05:10 PM   #2
Chicago, IL
Michael Thomas's Avatar
Unless this has already been done, or the bathroom outlet is already protected by a GFCI breaker, the existing switch/outlet should be replaced with GFCI switch/combo unit in any case to reduce the danger of electric shock / electrocution.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs
Michael Thomas is offline   Reply With Quote
Old 12-11-2009, 05:20 PM   #3
Does this switch operate the bathroom light?
If so, the recep shouldn't work at all so somethings miswired somewhere
220/221 is offline   Reply With Quote
Old 12-11-2009, 05:59 PM   #4
Licensed Pro
If that was originally a switch only (usually the case), then you only have a switch leg i.e., there is no neutral present to properly power the recptacle.
Old 12-11-2009, 06:19 PM   #5
joed's Avatar
You need at least three wire + ground for this to work properly. Replace it with a switch only device.
This was improperly installed on a switch loop. If you remove the bulbs from the light then I bet the receptacle doesn't work.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-11-2009, 06:50 PM   #6
You're right. If I take out the bulbs the outlet doesn't work. I put the bulbs back in and the outlet works when the lights are out. This has been like this for thirty years!! I just never used a plug in dryer with the lights on. Thank you all for the advice. I will replace it with a GFCI switch.
Old 12-11-2009, 07:30 PM   #7
Licensed Pro
Just putting in a GFCI switch won't work... you need another wire, either by adding an additional 12/2 or replacing what you have with a 12/3.
Old 12-11-2009, 08:04 PM   #8
joed's Avatar
You need to replace it with a switch. You can not have a receptacle there without rewiring. And since this will be a wiring change it will need to be a 20 amp circuit with #12 cable.
tiled walls, now the outlet and light switch are too deep! diy'er on LI Electrical 10 11-20-2009 08:32 PM
New outlet using power from a nearby switch. surecook Electrical 23 10-16-2009 07:27 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Outlet with a switch on top GTAgeek Electrical 3 01-28-2009 09:56 AM
Bathroom outlet - distance from tub?? plbsplbs Electrical 11 07-09-2007 09:22 PM
