Switch Or Not? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-15-2011, 07:04 PM   #1
switch or not?
I'm running some new 12-2 wiring to my pressure switch for my deep well located in my garage and was wondering if I need to put a switch inline before the pressure switch?
RROADHOGG is offline   Reply With Quote
Old 05-15-2011, 07:38 PM   #2
Electrical Contractor
kbsparky's Avatar
Generally, you should have a disconnect switch within sight for any utilization equipment.
"within sight" means you can actually see the switch from the equipment, and it's no more than 50 feet away. So, if you can see the pressure switch from the breaker box, then you won't need another disconnect at the equipment.
IF not, then you should install one, and if it's a 240 Volt circuit, you will need a double-pole switch to do the job.
-KB
Old 05-16-2011, 03:43 AM   #3
Rewards Points: 1,192
Something the well guys can put a lock out tag out on .Not just a switch.
bobelectric is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
