Switch For My Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2008, 12:16 AM   #1
listo's Avatar
Rewards Points: 95
Question
switch for my fan
the switch for my ceiling fan didn't seem to work. So i took the cover off the switch and it wasn't connected at all. The wire that is supposed to connect to the switch is cut to short to reach the switch. I went and checked the connection at the fan and the same wire is capped off in there so it's just a wire in the wall.
My question is...
Is this ok or do i need to remove that wire?
Also can i use the wire somehow even though it's only about a cm long in the switch and too short to attach it to another wire to make it longer to reach the switch, so is there a way i could extend it?
listo is offline   Reply With Quote
Old 11-19-2008, 09:33 AM   #2
bradnailer's Avatar
It is really hard to tell you what you can do without knowing a little more like what wires are coming into the switch box and how the wires in the box are connected.
For example, do you have a white, black and ground coming into the box? Is the black wire coming in to the box connected to the bottom of the switch? Are the whites all wire nutted together?
bradnailer is offline   Reply With Quote
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
old wire, backfed switch question Jack A. Trades Electrical 6 07-03-2008 11:05 AM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
