Switch Loop Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 01:23 AM   #1
Switch loop wiring
So I have a switch loop that powers an out side light. I wanted to add an additional light outside so I ran 12/2 wiring from the light junction box over to the new light's box. By doing so I increased the size of the loop. Old Black wire to to new black, new white to old light black, old light white to old wiring white. Are there any issues with doing this? It works as is, but I just want to make sure it is safe.
hammerthro is offline   Reply With Quote
Old 02-09-2012, 02:38 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If it is like this your good ...
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
zappa (02-09-2012)
Old 02-09-2012, 08:15 AM   #3
Licensed electrician
Rewards Points: 1,010
If you want the new light switched at the same time as the old fixture follow Stubbies diagram. You have the wire colors switched in your description.
zappa (02-09-2012)
Old 02-09-2012, 08:50 AM   #4
Awesome info. I've been looking all over for a diagram like that. Thanks guys.
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Wiring a New Light Switch but Problems nlsnrn Electrical 8 08-31-2011 04:36 PM
Radiant heater thermostat switch wiring question tumblinman Electrical 12 07-11-2011 11:05 PM
Different wiring on replacement dimmer switch kmmccorm Electrical 2 01-09-2010 07:48 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 09:00 PM
