Switch Loop Series + Hot - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 07:06 PM   #1
DIYer
Rewards Points: 93
Switch loop series + hot
Hi all
I'd like to wire two overhead fluorescent lights to one switch and then have another switch in that box control two more lights. So the arrangement would be like this:
Code:
Source->Light->Light->Switch->Switch->Light->Light
It seems I will need a 2 wire source, then 3 wires between the first light and the second and the second light and the switch box. Yes?
I think I understand how to do this but just want to get confirmation from the board
So I'd make the red wire between the two lights be the switch loop and just continue the black wire to the switch box. Yes?
Thanks in advance
dwoloz is offline   Reply With Quote
Old 08-16-2010, 07:54 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Is this what you want?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-16-2010, 08:05 PM   #3
DIYer
Rewards Points: 93
This is my lovely drawn diagram, hopefully it's clear
Old 08-16-2010, 08:09 PM   #4
joed's Avatar
Rewards Points: 13,696
You are correct. You need three wire cable between the first two lights and the first switch. This image has only one light but it should give you an idea of what is required.
Old 08-17-2010, 04:24 AM   #5
Tool Geek
PaliBob's Avatar
DW, If you have existing wiring where one switch controls two lights and the second switch controls the second set of two lights then a simple rewire of S2 (as I showed in Post #2) will make the second set of lights dependent on S1 AND S2.
The attached diagram is applicable only if you do not already have two switches with separate cables to each set of lights.
Your Diagram is wrong in that the AC is switched On/Off to the light. There is no AC power at the lamps unless the Light switch is On.
Note: If the AC input to the Light ckt is on a 20 amp feed then the feed to the lights on the diagram has to be 12-3
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-17-2010, 09:56 AM   #6
Rewards Points: 1,548
What each cable does:
Power to first light. Requires two conductors for raw (unswitched) power and neutral.
First light to light box connected to first switch. Requires three conductors, raw power for all lights, switched power coming back from switch to first group of lights, and neutral.
Light box connected to first switch, down to said switch. Requires three conductors, for raw power to all lights, switched power going back to first group of lights, and neutral.
Between the switches. The incoming raw power is connected to both switches (using two pigtails). For those eavesdropping, if the switches are in different boxes, use two conductor cable to carry raw power and neutral between the switch boxes.
Second switch to and through second group of lights. Requires two conductors, switched power to those lights, and neutral.
Old 08-17-2010, 11:23 AM   #7
Tool Geek
PaliBob's Avatar
Originally Posted by AllanJ View Post
.....Power to first light. Requires two conductors for raw (unswitched) power and neutral.......
The OP was not correct in showing raw AC connected to the lights. The OP also shows the two switches in the same box.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-18-2010, 02:18 PM   #8
Post #4 would be correct for what the OP wants.
Willis
williswires is offline   Reply With Quote
Help with 3 way switch loop wylde8 Electrical 7 12-17-2009 05:53 PM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
To Switch loop or not to switch loop beezlebub03 Electrical 7 06-17-2008 06:04 PM
switch loop aokss Electrical 13 05-07-2007 08:41 PM
