Switch Loop Detached Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2009, 02:07 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Switch loop detached garage
Hi guys
Working on wiring the detached garage today. Can anyone refresh my memory, does a switch loop for a light on the garage get power from the garage and only switching wires travel back to the house in the conduit?
Thanks very much
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-10-2009, 06:34 PM   #2
hard to tell you with that little info. Open one end, light or switch and tell us what you see.
II Weeks is offline   Reply With Quote
Old 02-10-2009, 07:24 PM   #3
DIY'er
jamiedolan's Avatar
HI;
This is all brand new, I ripped everything out. I am going to put a light on the garage that is operated by a switch in the house. So I will be running a switch loop in the underground conduit to the garage. I believe that the fixture on the garage needs to be power from the panel in the garage, and you just run a switch loop back to the house.
I just wanted to confirm that the power should be coming from the detached structure, so I comply with the single point of disconnect rule. I am currently reading over the single point of disconnect rule in the NEC, but am having trouble finding the switch loop exemption.
Jamie
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 12:08 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
To Switch loop or not to switch loop beezlebub03 Electrical 7 06-17-2008 06:04 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
