Old 06-07-2012, 11:05 PM   #1
Question
Switch loop
Have a question ...Today I wired a ceiling fan using a switch leg in an attic that was powering a light fixture with a pull chain. The ceiling fan and light fixture are at the end of the cable run.
Basically i need to know the best way to reinstall the light fixture, because it obviously does not operate properly in that setup.
Was not sure if i could A) do a switch loop out of that junction box, to a new box, then to a new switch for the light or B) do a switch loop to the new fan switch.
My feeling is that I should leave the fan/light as they are, and look for a new source for the light.
Any advice would be appreciated.
Gratephul is offline   Reply With Quote
Old 06-07-2012, 11:18 PM   #2
joed's Avatar
Switch loop
I do not understand what you had and what you want. I think you had a light fixture that had a pull chain.
Is the fan a replacement for the pull chain fixture? in the same box as the Pull chain? In a different box as the PC?
Do you want a switch for the light and the fan? two switches, one for each? a switch for the fan only?
What cables do you have? What cables did you add?
Do not PM with questions that can be asked in a forum. I will not respond.
Old 06-07-2012, 11:28 PM   #3
Switch loop
I installed a ceiling fan/light in a bedroom, ran 14/3 over to 2 new switches on the wall...one for the fan, one for the light. To power the switches, I tapped into an existing light fixture (with pull chain), in the attic. However i realized that the pull chain light was very dim, etc.
So i eliminated the light fixture(with pull chain) for the time being, and the fan and light fixture work great.
So in the morning i need to find a solution for the light fixture in the attic (the one with the pull chain).
Old 06-07-2012, 11:35 PM   #4
Electrical Contractor
Switch loop
How did you wire the pull chain light back into the circuit?
A pull chain light dosen't use a switch loop.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 06-08-2012, 06:49 AM   #5
Switch loop
I did not wire the pull chain fixture back in yet, that's really the question...how do i get the pull chain fixture back in there without affecting the new light/fan.
Thanks for the reply
Old 06-08-2012, 07:03 AM   #6
Switch loop
AFter you installed the fan/light combo you say the pull chain lite in the attic was dim. Did the fan/lite combo function properly at this time. Or did the fan/lite combo function "great" only when you eliminated the pull chain lite?
A setup like below will work.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Gratephul (06-08-2012)
Old 06-08-2012, 09:20 AM   #7
joed's Avatar
Switch loop
In the PC fixture you should have two black connected, two whites connected and the grounds connected. Add a black and white pigtail to these bundles and connect them to the PC socket.
The Following User Says Thank You to joed For This Useful Post:
Old 06-08-2012, 10:36 AM   #8
Switch loop
Thanks!...that was the problem; i had not pigtailed the neutral to the pull chain fixture.
3 way switch replacement in 1923 old house elcc1958 Electrical 3 02-06-2012 09:42 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
3-way switch help amit Electrical 17 02-15-2010 04:17 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
switch loop aokss Electrical 13 05-07-2007 09:41 PM
