Switch Leg - Which Is Correct? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 05:50 PM   #16
Rewards Points: 141
My confusion is with the terms. Correct me if I'm wrong but I think there is a difference between the terms switch leg (the conductor that goes from the switch up to the light to energize it; power entering the switch) and switched leg.
RocketGal is offline   Reply With Quote
Old 01-30-2014, 05:58 PM   #17
Licensed electrician
Rewards Points: 1,008
Originally Posted by plummen View Post
Well I just looked up the article, makes no sense to me as to why they want it that way if its identified as power, but what ever makes them happy I guess.
The down on white, back on black keeps you from having two whites at the fixture. Prior editions of the code did not require the white to be reidentified as it was assumed that it was understood the white was hot.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
icepal1999 (01-30-2014), RocketGal (01-31-2014), stickboy1375 (01-30-2014)
Old 01-30-2014, 06:19 PM   #18
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
We were identifying them with black tape around here since the late 70s.
I got my contractors license back in 96 and in all the years of continuing ed classes since then ive never heard it being brought up.
Ive never to this day had an inspector climb up to check the inside of a fixture box to see how it was taped on a rough in/remodel inspection.
Of course I was also told at a young age to never leave a ladder sitting out for an inspector to climb on. Hahaha
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-30-2014, 11:56 PM   #19
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Neither is legal for new work without the neutral in seitch box.
Maybe or maybe not. IMO the main basis for a neutral to show up in switch boxes was primarily aimed at commercial work where devices like occupancy sensors are commonly installed after the fact and when a neutral wasn't present they were using the egc to carry the current to operate the device.. There are a few states that are now including an exception 3 to 404.2 (C). that amends the NEC requirement.
Exception (3) one and two family dwellings
404.2 Switch Connections (C) Switches Controlling Lighting Loads . NCHBA proposed amendment that exempts Residential one-and two-family dwellings from the grounded conductor requirement at lighting switch locations
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-31-2014, 05:08 AM   #20
Rewards Points: 2,494
Originally Posted by icepal1999 View Post
Which is correct and why? Code reference if possible.
1) Power comes into light:
- White tied into white of fixture
- Black is tied into the black to the switch
- White from switch tied into black of fixture (taped black at both ends)
2) Power comes into light:
- Black is tied into the white to the switch (taped black at both ends)
- Black from switch tied into black of fixture
The switch leg(the conductor returning switched power from the switch to the device) cannot be white. The white conductor of the switch loop must be the conductor taking power to the switch.
#1 is not code-compliant but it will function as electricity does not care what color the insulation is on the conductor.
#2 is code compliant and will function
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Old 01-31-2014, 05:15 AM   #21
I know someone will point out that there is no neutral at the switch location so here it is in #2
Old 01-31-2014, 06:31 AM   #22
Chewy - Lic. Electrician
On a switch loop like in fig 1, you always feed the switch with the white wire and have the return back to the light black.
SGC622 is offline   Reply With Quote
Old 01-31-2014, 10:59 AM   #23
That is not what diagram #1 shows. Diagram #1 shows the switch being fed by the (constant hot)black-wire and the (switched hot)white-wire feeding the light.
It will function but is node code compliant.
Old 01-31-2014, 11:08 AM   #24
plummen's Avatar
That was the first thing I mentioned.
Old 01-31-2014, 11:20 AM   #25
Rewards Points: 121
Thank you all for the information. Should make this post a sticky!
As mentioned before - just changing fixtures and switches - wanted to do it the right way. Simple fixture and simple SP switch.
If I ever do new work, will feed the switch with a 3 wire if power is to the fixture. Obviously no need for a 3-wire if power to the switch first.
icepal1999 is offline   Reply With Quote
Old 01-31-2014, 11:26 AM   #26
Rewards Points: 808
What is the reason for the OP to worry about code compliance in an already existing installation? There's no reason to change anything when simply replacing a fixture and/or switch. Code compliance kicks in for NEW installations, not upkeep or maintenance or replacement of an already existing install.
IslandGuy is offline   Reply With Quote
Old 01-31-2014, 11:37 AM   #27
joed's Avatar
Rewards Points: 11,524
In #2 I personally like to use the red as the switched power. There is no code requirement for that but a personal preference.
The Following User Says Thank You to joed For This Useful Post:
Stubbie (01-31-2014)
Old 01-31-2014, 12:42 PM   #28
UAW SKILLED TRADES
Stubbie's Avatar
Because he is asking and wants to be sure his wiring is correct
Even if that existing install is not code compliant ...
Stubbie
The Following User Says Thank You to Stubbie For This Useful Post:
icepal1999 (01-31-2014)
taco sr503-4 switch jmon HVAC 53 11-12-2012 07:26 PM
Rewire a switch that controls an outlet. z00ropa Electrical 8 10-23-2012 07:00 PM
Adding Light Switch - Outlet - Light > Correct wiring ? westbank Electrical 4 09-15-2012 11:42 AM
confused on switch replacement fullpint Electrical 6 07-11-2011 09:39 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
