Switch Leg - Which Is Correct? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 12:57 PM   #1
Rewards Points: 121
Switch Leg - which is correct?
Which is correct and why? Code reference if possible.
1) Power comes into light:
- White tied into white of fixture
- Black is tied into the black to the switch
- White from switch tied into black of fixture (taped black at both ends)
2) Power comes into light:
- Black is tied into the white to the switch (taped black at both ends)
- Black from switch tied into black of fixture
Thanks for your help in advance!
icepal1999 is offline   Reply With Quote
Old 01-30-2014, 01:15 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
You could wire it several differant ways.
You could run to fixture first then run a piece of 14/3 to the switch box .
If you do it that way take the nlack wire from the feed and tie it to the black or red from the 14/3 and run it to one side of switch.
Then use the other colored wire black or red for other side of switch.
The white wire just gets capped off in switch box as a future neutral.
At the fixture box the unused red or black from the 14/3 gets tied into the black wire from fixture.
The whites get tied together with the white wire from the fixture.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-30-2014, 01:18 PM   #3
Rewards Points: 121
Interesting. But the 2 scenarios I describe - which is correct. I know they both work , just want to be code compliant.
Old 01-30-2014, 01:19 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 484
#2 is correct, but new code requires a neutral at the switch location. No code ref.
The Following User Says Thank You to jbfan For This Useful Post:
sirsparksalot (01-30-2014)
Old 01-30-2014, 01:20 PM   #5
plummen's Avatar
Neither is legal for new work without the neutral in seitch box.
Old 01-30-2014, 01:32 PM   #6
Rewards Points: 121
All existing. Just changing fixture and replacing the switch.
So #2 it is?
Old 01-30-2014, 01:49 PM   #7
plummen's Avatar
So #2 it is?
The switch will work either of the 2 ways you posted.
You asked what was legal code wise, you didnt mention anything else as far as details.
Old 01-30-2014, 01:49 PM   #8
Rewards Points: 512
So #2 it is?
Yes, #2.
Installation is the Reverse of Removal.
Old 01-30-2014, 01:50 PM   #9
joed's Avatar
Rewards Points: 12,902
Disregarding the neutral requirement, #2 is correct. No code reference, but the reason is so that you don't have two whites connecting to the fixture, even if one is taped.
The Following User Says Thank You to joed For This Useful Post:
icepal1999 (01-30-2014)
Old 01-30-2014, 01:52 PM   #10
Rewards Points: 121
Great, thanks everyone for the info.
Ironically I did read about having the neutral in the box for new stuff - I think it was so new switches/dimmers that need a neutral now have one.
The Following User Says Thank You to icepal1999 For This Useful Post:
plummen (01-30-2014)
Old 01-30-2014, 01:53 PM   #11
Rewards Points: 512
Working, and correct isn't the same. I don't have the code ref., but you don't want to have two whites at the light fixture, even if one of them is taped or running to a black pigtail, as seems the situation here.
The Following User Says Thank You to sirsparksalot For This Useful Post:
Old 01-30-2014, 03:02 PM   #12
Licensed electrician
Rewards Points: 1,622
Article 200.7(C).
Old 01-30-2014, 03:13 PM   #13
plummen's Avatar
Maybe im missing something here, I thought I read he was labeling the extra white wire with black tape to identify it as a power wire.
Thats what im seeing with both ways he wrote it up.
Old 01-30-2014, 03:18 PM   #14
plummen's Avatar
Looks to me like hes identifying the white wire with black tape here, am I missing something here?
Or am I the only one that sees taped black on both ends of white wire in option one?
To me that means hes marking it with black tape in the light box and in the switch box, ive never seen an inspector tag something like that anyway.
Well I just looked up the article, makes no sense to me as to why they want it that way if its identified as power, but what ever makes them happy I guess.
Old 01-30-2014, 04:40 PM   #15
Rewards Points: 121
Yes - the white wire is taped black at both ends (in the switch box and the fixture).
I too looked up Jim's reference NEC 2011 200.7 (c)(1) and it's all good.
Joed's response made since as well - don't want two white wires hooked up to the fixture - can cause confusion.
Does anyone have the NEC code reference for the neutral/grounded conductor to be present in the box?
I have NEC 2011 404.2 (a) exception.
taco sr503-4 switch jmon HVAC 53 11-12-2012 06:26 PM
Rewire a switch that controls an outlet. z00ropa Electrical 8 10-23-2012 06:00 PM
Adding Light Switch - Outlet - Light > Correct wiring ? westbank Electrical 4 09-15-2012 10:42 AM
confused on switch replacement fullpint Electrical 6 07-11-2011 08:39 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
