Switch Help - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 08:26 AM   #16
Rewards Points: 2,516
Sorry.. I sscrewed that up
hammerlane is offline   Reply With Quote
Old 09-14-2012, 08:27 AM   #17
Yes correct
banana man is offline   Reply With Quote
Old 09-14-2012, 08:33 AM   #18
can u provide a photo of the conductors inside the switch box location...in other words looking into the box
Old 09-14-2012, 08:35 AM   #19
Do you mean like this ?
Old 09-14-2012, 08:42 AM   #20
Disconnect wires A, B, C, one at a time and each time you disconnect one try the switches and see what does not light.
Old 09-14-2012, 08:51 AM   #21
A does nothing all still turn on
B turns off upstairs
C turns everything off
Old 09-14-2012, 08:55 AM   #22
in your sequence above...did you replace "A" before removing "B" and so on. So did you only have one wire disconnected at any thinme while performing your test?
do you have a voltage meter...that you can double check that the wire I marked as always hot is always hot
Old 09-14-2012, 08:56 AM   #23
No I don't !
Old 09-14-2012, 07:52 PM   #24
the Musigician
DangerMouse's Avatar
To all of our regular contributing members: Please DO NOT reply to posters who post questions in the "How To" section. It plainly says PLEASE DO NOT POST QUESTIONS in HERE!
This thread will be moved after you get a chance to read this.
Thank you
DM
Old 09-14-2012, 07:59 PM   #25
Oops my bad newby mistake
Old 09-15-2012, 10:08 AM   #26
An old Tradesmen
Rewards Points: 7,802
Moved to Electrical forum.
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
