Switch Height - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 02:53 PM   #1
Switch Height
How high do I install light switches?
MikeyP is offline   Reply With Quote
Old 01-25-2009, 02:58 PM   #2
Electrical Contractor
kbsparky's Avatar
How high do you want them?
We usually install them at 44" to the bottom of the box, same height as our counter-top receptacles.
I've seen them as low as 40" to the bottom, while others were up high, along the lines of 54" or more.
Certain handicapped units may have other requirements, such as 36" or so.
Depends on the situation.
If you are looking for a Code reference, there isn't any ...
Old 01-25-2009, 03:01 PM   #3
Rewards Points: 150
As far as I know there is no rule in the code. I normally place the top of the electrical box 48 1/2" from the top plate (in new construction) so that when the drywall'ers put up the drywall they only have to cut one piece for the box. As far as adding an old work box anywhere in the 45 -48" range (from the floor) is usually a comfortable height.
Steelhead is offline   Reply With Quote
Old 01-25-2009, 03:02 PM   #4
Junction Boxes
I'm adding a couple of lights to our bathroom. The switches for both light will be in the same box. Since I have complete access I was going to run a wire to both switches from a junction box rather than 1 wire with a pigtail to service both switches. Good idea??? Bad idea???
Old 01-25-2009, 03:05 PM   #5
Rewards Points: 150
One incoming cable for power is just fine. No need to run one for each switch.
Old 01-25-2009, 04:06 PM   #6
how high for your switch
in the uk the maximum height of a switch is 1200mm.
shaunbernard is offline   Reply With Quote
Old 01-25-2009, 04:29 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Make them the same height as the rest of the switches in your house.
Old 01-25-2009, 04:35 PM   #8
switch height
new installs are 1200mm max, existing, i would go with speedy pete
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
changing a fixture to an outlet - keeping the switch aweshucks Electrical 4 12-27-2007 05:06 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
