Switch Has Pos/nutrual, Is This Okay? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 12-30-2013, 05:55 PM   #16
Originally Posted by sublime2 View Post
Your argument is weak at best in regards to it not being fine.
the white conductor is not marked at the switch so it is already not fine
itsnotrequired is offline
Old 12-30-2013, 06:07 PM   #17
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Originally Posted by RyanD View Post
Just odd seeing a white wire used as hot.
No, it's really not at all.
If you were familiar with this stuff you'd know that.
It's good that you are questioning things, but just because you think it's not right or is odd does NOT mean that it is.
Speedy Petey is offline
Old 12-30-2013, 06:08 PM   #18
Licensed electrician
Rewards Points: 1,788
Earlier editions of the code did not require the white to be reidentified as they assumed people working on this would know what was going on. The code has been dumbed down to account for less knowledgeable people working on wiring.
Jim Port is offline
The Following 5 Users Say Thank You to Jim Port For This Useful Post:
beenthere (12-30-2013), HouseHelper (12-30-2013), k_buz (12-30-2013), Speedy Petey (12-30-2013), stickboy1375 (12-31-2013)
Old 12-30-2013, 06:14 PM   #19
Originally Posted by jeffnc View Post
I would not be so hasty to brush this off and say "it's fine". There's still the possibility that the white wire is hot. The most common mistake is what you mentioned - they just didn't recode the white wire as black. If they didn't know to do that, it's possible they made a worse mistake, which is wiring this switch loop on the neutral wire. In other words, the light or outlet picks up a hot wire from a different direction, and then runs this switch loop to the neutral. This is a potentially dangerous situation, where the circuit appears to work just fine. For example, a light is connected to the switch, and the light turns on and off just fine. However the problem is the light is off, but still has a live hot wire connected to it. You wouldn't know that if changing the light bulb, or worse working on the circuit with the switch off but the breaker on.
Well, it IS fine. The chances that this was wired switching the neutral are pretty slim. A switch loop is a hugely common thing, especially in older homes. As Jim said, re-marking the conductor is a relatively new thing in the scope of things time wise.
Why you would go on a long diatribe as to how bad it could be is a mystery.
I see your previous reply was removed so I can't comment on that. I guess you realized it was wrong.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Jim Port (12-30-2013)
Old 12-30-2013, 06:14 PM   #20
See post #18.
Old 12-30-2013, 06:17 PM   #21
Originally Posted by Speedy Petey View Post
See post #18.
i'm aware of the history, should have clarified my response is based on '99 code or newer.
op, how old is the house?
Old 12-30-2013, 06:19 PM   #22
An old Tradesmen
Rewards Points: 7,818
More like I don't like bickering in threads.
beenthere is online now
The Following 2 Users Say Thank You to beenthere For This Useful Post:
BigJim (12-30-2013), oh'mike (12-30-2013)
Old 12-30-2013, 06:25 PM   #23
Oh, I though he deleted it.
Old 12-30-2013, 06:38 PM   #24
Rewards Points: 4,796
I haven't removed anything, and I'm not wrong about anything. Maybe you misread my post. When I said "don't be hasty to assume it's fine", I said the switch might switch the neutral line, which is not fine. And you have no idea if that was true when I wrote it. Everyone was telling him his circuit was perfectly fine and he hadn't even identified where the wire was going yet. Just because a lot of people don't recode white wires on switch loops does not prove his circuit is fine, so I suggested he do a little more looking.
It was recommended to the OP to read Black and Decker Complete Guide to Wiring. In that book it explicitly states "A white hot wire should be coded with black tape or paint."
To recommend he read this book, then tell him everything is perfectly fine, is confusing at best.
jeffnc is offline
Old 12-30-2013, 06:47 PM   #25
All you are doing is assuming that something that is perfectly typical and normal COULD be wrong. The same could be said for EVERYTHING in a home, wiring and otherwise.
Given the age of the wiring in question re-marking was not required, so WHY assume something is wrong???
Old 12-30-2013, 06:49 PM   #26
Switched neutrals stopped being used just after knob and tube wiring.
Jim Port is offline
Old 12-30-2013, 06:56 PM   #27
doesn't look like the grounding conductor is connected to anything. was it disconnected and tucked out of the way for clarity of the photo? or was it found that way, stuffed back in the box with no connection?
Old 12-30-2013, 06:58 PM   #28
You are misreading my post to suit your argument. I did not assume anything is wrong. What I'm saying is, just because it's common to wire a switch loop with a white wire does not mean you should assume all the rest of the circuit is correct if you haven't even looked at it. I gave him one example among thousands, which doesn't mean any of them are particularly likely. But wiring mistakes in general are pretty common.
jeffnc is offline
Old 12-30-2013, 07:03 PM   #29
You are misreading my post to suit your argument. I did not assume anything is wrong. What I'm saying is, just because it's common to wire a switch loop with a white wire does mean you should assume all the rest of the circuit is correct if you haven't even looked at it. I gave him one example among thousands, which doesn't mean any of them are particularly likely. But wiring mistakes in general are pretty common.
Whatever. I am not trying to argue. I am just trying to clear up confusion/incorrectness in your posts.
Either way, I'm done. The mods have already had to clean up this thread and I don't to cause them any more work.
Old 12-30-2013, 07:03 PM   #30
An old Tradesmen
Question asked, question answered.
The thread is spiraling, the thread is closed.
RyanD, please start a new thread if you have anymore questions about this. PM me if you start another one so it can be watched right a way, thank you.
The Following User Says Thank You to beenthere For This Useful Post:
gregzoll (12-30-2013)
Closed Thread
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 05:31 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
