Switch Grounding - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2009, 07:07 PM   #1
switch grounding
I know in certain situations receptacles dont have to grounded.
What about switches? Do they always have to grounded?
Steven Jackson is offline   Reply With Quote
Old 02-09-2009, 07:26 PM   #2
If the box is metal and is grounded, the switch is flush with the box (washer removed), you don't need to ground the switch.
rgsgww is offline   Reply With Quote
Old 02-09-2009, 08:05 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Receptacles must always be grounded. A "self-grounding" receptacle mounted to a grounded metal box does not need a jumper, nor does one mounted firm to a metallic box.
NEC 250.146(A)&(B)
ANY switch simply mounted to a grounded metallic box is grounded. Switches to not need to sit tight to a box nor do they need self-grounding clips.
The only time a switch does not need any grounding is a replacement switch in an ungrounded application.
NEC 404.9(B)
Old 02-09-2009, 08:28 PM   #4
What about to a plaster ring to a box?
Old 02-09-2009, 08:51 PM   #5
Registered User
Termite's Avatar
If the mudring is metal and it is attached to the grounded metal box, I'd say it is safe to assume that the mudring is effectively grounded. If the mudring is plastic then you'd need a jumper to the device.
Switches in plastic boxes must always be grounded.
Old 02-09-2009, 09:23 PM   #6
Awesome thanks guys.
grounding switch? Jeremy Hillary Boob, PhD Electrical 15 08-02-2012 04:51 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
