Switch Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 10:28 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Switch Ground
What is the reason for the grounding screw on some of the newer, premium light switches? Is it always necessary to bond the switch to ground, assuming the rest of your fixture / circuit is grounded?
Jamie
jamiedolan is offline   Reply With Quote
Old 10-28-2008, 10:40 PM   #2
Rewards Points: 2,350
Jamie
Because you can put a metal face plate on it and the grounded metal strap is what bonds that plate to ground. Even when using a plastic plate, the metal screws are still exposed and need to be bonded. If the yoke were plastic, then there would be no need to ground them.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
does a switch in an old work box require a ground? jheavner Electrical 7 10-04-2008 11:09 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Two ground wires for one switch, none for another? josquin Electrical 5 07-01-2007 02:31 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
