Switch To Garbage Disposal Question - Electrical - Page 5 - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 10:10 AM   #61
Originally Posted by k_buz View Post
The dishwasher can be put on a 14-2 (with ground) appliance cord legally as the dishwasher itself doesn't need a 20A circuit.
ah that's good to hear.
my question, since i havent done this before.
the best chord i found was a simple #14 6' extension chord. can i simply just cut into it and splice it at the dishwasher's junction.... or do i need to do anything special? I assume the chord will have the basic 3 wires - white/black/ground. am i assuming wrong?
someone earlier mentioned bushings - havent found anything yet to support that.
i'll look this information up on my own in time. just figured i'd bounce my confusion off you guys since you've been such a tremendous help so far.
tard01 is offline   Reply With Quote
Old 03-28-2012, 10:16 AM   #62
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Lowe's should have something like this. I would have provided a link to a Lowe's product, but their website is down for maintenance right now.
Old 03-28-2012, 10:29 AM   #63
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Permits & Inspections are usually required for ALL electric work
It may not be legal for you to do your own work, Check with your local Building Dept
Quoted from NEC- National Electric code 2008
Question;
Does the above mean that the fact that he is doing the cord/cable himself is in fact illegal?
sublime2 is offline   Reply With Quote
Old 03-30-2012, 05:13 PM   #64
rewired it correctly with a plug outlet and a "disconnect" cable.
Old 03-30-2012, 05:19 PM   #65
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
two switch ceiling fan/ light question ifthenelsenull Electrical 4 12-29-2011 03:23 PM
light switch wiring question. dannat Electrical 4 05-05-2011 09:11 AM
Connecting new dishwasher and garbage disposal -- no ground wire in the conduits. arca Electrical 17 03-28-2011 02:06 AM
can switch work for two different outlets? jlmran Electrical 8 02-10-2011 12:31 PM
Garbage Disposal Question Tizzer Appliances 1 10-09-2010 07:49 PM
