Switch Or Fixture? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 06:46 PM   #1
Switch or Fixture?
So, all you nice folks helped fix my first light switch which worked out great! Now my new problem...first, it's a different switch/light then the one I fixed last time. I put in a new light switch...light still doesn't work, so I figure maybe the fixture/socket is bad and I get a new fixture w/socket and it still doesn't work. I double and triple checked my work and see nothing wrong. It's not a fuse problem, not a bad light switch and not a bad light socket....what else can a check? It's a bedroom ceiling light, single socket light fixture.
Once again I ask for any advice, suggestion or ideas. Thanks so much!
Anne
saggioculo is offline   Reply With Quote
Old 03-30-2012, 06:49 PM   #2
joed's Avatar
Rewards Points: 12,006
Measure voltage at the light to neutral. Tell us about the wires in the fixture and the switch. Did you try a new bulb?
Old 03-30-2012, 07:00 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Is this switch wired the same as your last one that you fixed?
Pics always help.
sublime2 is offline   Reply With Quote
Old 03-30-2012, 07:09 PM   #4
I don't know how to "measure voltage at the light to neutral". Wow! I may be a woman but I did try changing the bulb first!
Old 03-30-2012, 07:10 PM   #5
Pics always help.
Yes...did everything the same way. The fixture only had three wires and I hooked up the new the same as the old.
Old 03-30-2012, 07:28 PM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
so the switch had 2 sets of wires going to the box and 1 set of wires at the fixture?
Old 03-30-2012, 08:20 PM   #7
Yes, the switch had 2 "sets" of wires where the fixture had three wires, white/black/bare wire which is what the fixture had.
Old 03-30-2012, 08:22 PM   #8
Rewards Points: 115
whether power originates at the light fixture or the switch you have to determine if you even have power present. how do you know that you have power if you do not know how to check for voltage?
pokey is offline   Reply With Quote
Old 03-30-2012, 10:24 PM   #9
joed's Avatar
Where is this new fixture? Could it be on a GFCI circuit that has tripped?
Old 03-31-2012, 12:11 AM   #10
Rewards Points: 506
Did you turn the breaker back on after you finished the work? I've forgotten to do that before.
jlmran is offline   Reply With Quote
Old 03-31-2012, 09:12 AM   #11
OK...there is one circuit breaker for the lights in and around the area of my bedroom, when I turn them off, everything in my room goes off, so that breaker turns off the outlets as well. I can only assume that there is power to the light because when I turn that breaker back on, everything in my room works again...except the light of course.
As for checking the "volts", I've seen it done in other situtations, it's a little box with two wires that have clips on the ends. I believe I have one of those in my garage. So, I guess my next "thing to try" would be testing power for the light. Do I check at the switch or the light fixture?
Old 03-31-2012, 09:17 AM   #12
Rewards Points: 2,516
In the box with the switch, are there two white wires wire nutted together?
If so you may have a loose neutral. Jiggle the bundle of white wires and see if light comes on. If light comes on then take wire nut off, align the white wires and twist back on the wire nut.
hammerlane is offline   Reply With Quote
Old 03-31-2012, 09:27 AM   #13
Rewards Points: 1,574
Might try viewing: http://video.about.com/electrical/Ho...t-Switches.htm
for a general idea of how to test the wires at your switch for any power.
Be careful, you have to do this with the circuit breaker/fuse on!!!!
bob22 is offline   Reply With Quote
Old 03-31-2012, 09:31 AM   #14
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you do this, make sure you turn the power off.
Old 03-31-2012, 10:13 AM   #15
Will need power to be on while jiggling the neutral(white) to see if light comes on...meaning the neutral was loose.
They can turn power off at breaker while re attaching wire nut if needed.
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Add new lgt fixture and switch to existing lgts and switch? jwoodnik Electrical 3 09-19-2009 10:29 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
New Switch / Ceiling Fixture - Help nelrolo3 Electrical 1 03-12-2004 07:11 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 11:51 PM
