Switch Conversion Possible? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2011, 09:23 PM   #1
switch conversion Possible?
I have a three way switch setup that I would like to do away with. Instead of the three way switches, I would like to install a single pole switch and add a receptical. Can I do this using the existing wireing? If so, how do I go about it? Thanks
compost is offline   Reply With Quote
Old 02-14-2011, 10:40 PM   #2
I=E/R
a7ecorsair's Avatar
It is possible but you must have a neutral in the switch box where you will do the change. If power to the current three way switch is fed to the box you'll have the neutral. If power is fed to the light and all you have is a switch loop then you won't have a neutral.
a7ecorsair is offline   Reply With Quote
Old 02-15-2011, 07:44 AM   #3
Rewards Points: 1,548
Traditional configurations:
power - light - switch = switch (no)
power - switch = switch - light (yes)
power - switch = light = switch (yes)
power - switch = switch (no)
light
switch = power = switch - light (yes)
2011 NEC compliant configurations have a neutral at every box including switch boxes and any 3 way setup can be converted into a regular switch plus a receptacle.
Old 02-20-2011, 04:19 PM   #4
3-Way Switch Conversion to two way
Thanks for your replies. Allen, Could you please expand on your reply? I am confused and need clarification. Thanks
Flavio is offline   Reply With Quote
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
1 pole + 3 way switch momof2labs Electrical 1 05-22-2010 10:37 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
