Switch Controlled Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2011, 09:56 AM   #1
I have an outlet in my room that is only hot when I flip a switch on the wall. I have been in places before where the switch only controls the bottom half of the outlet and the top is hot constantly. Is there a way I could do this to my current outlet?
Thanks!
haze90 is offline   Reply With Quote
Old 08-11-2011, 10:25 AM   #2
Rewards Points: 1,514
Not if there are only two wires coming into the box, one wire attached to each side of the receptacle (outlet) unit.
AllanJ is online now   Reply With Quote
Old 08-11-2011, 08:51 PM   #3
joed's Avatar
Rewards Points: 12,898
Turn off the breaker and pull the receptacle out. Tell us all the wires connected to it and to each other in the back of the box.
Combo light switch outlet re-wire question seasidediy Electrical 3 07-21-2011 05:02 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Outlet controlled by a wall switch rwright46 Electrical 5 04-30-2009 05:00 PM
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 08:08 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
