Switch To Control GFCI Outlet Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 07:37 PM   #1
Rewards Points: 14
Switch to control GFCI outlet receptacle
Hello,
I have installed a GFCI receptacle outdoor which connects to the water fountain pump. I need to control this fountain from inside the house, so that do not have to pull out the plug everytime to shut-off the fountain.
My question is, is it ok to install an on/off switch indoor to control the GFCI Receptacle. Does the code permit. If not, what options do I have? I live in Ontario, Canada.
Your help would be appreciated.
FLDS
Last edited by flds; 07-26-2010 at 07:42 PM. Reason: I should have mentioned the place I live
flds is offline   Reply With Quote
Old 07-26-2010, 07:57 PM   #2
Electrician
Proby's Avatar
Yes, that is fine.
Be aware, some GFCI receptacles reset to the "Tripped" position when the power goes off (or you turn the switch off). You need to make sure that you aren't using one of these, or else you would have to go press the RESET button every time you turn the switch ON.
Proby is offline   Reply With Quote
Old 07-26-2010, 09:33 PM   #3
Rewards Points: 14
Proby,
Thanks for your response.
I do have a similar connection in our back yard and it works fine. The one I want to install is in the front.
Thanks once again.
FLDS
Switch outlet in bathroom odale Electrical 7 12-11-2009 07:04 PM
Additional Wall Switch to control light tiame Electrical 6 07-03-2009 11:54 PM
GFCI Breaker & GFCI Outlet together??? abinpa General DIY Discussions 6 04-12-2009 08:59 PM
Tracing light switch to an outlet allanet Electrical 13 04-03-2009 08:44 AM
GFCI receptacle gets tripped by hallway light proofer Electrical 10 03-17-2008 07:29 PM
