Switch Box To Small - Electrical - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 10:10 PM   #1
Switch box to small
I had to remove an existing switch box from my wall and it tore out some of the drywall. Now the height of the hole is too big. Any idea how I would secure a box in a wall that will eventually have a switch for recessed lights. I went and got a box that has metal flaps on the side that spreads out when you turn the screws, but the problem is that the top and bottom doesnt touch the drywall.
timchi29 is offline   Reply With Quote
Old 11-17-2010, 10:20 PM   #2
Journeyman Wireman
Rewards Points: 150
If your hole is adjacent to a stud use a "smart box" and then patch around any remaining gaps in the drywall.
http://www.licensedelectrician.com/Store/SmartBox.htm
Jupe Blue is offline   Reply With Quote
Old 11-17-2010, 10:32 PM   #3
It is 3 inches from the edge of the hole to the stub, so that would work.
Old 11-18-2010, 04:48 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Relocate the box next to stud and patch the old hole.
or
Cut out a piece of drywall larger than the existing hole, install a patch, cut new hole for box.
Coastal South Carolina
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 02:17 AM
3-way switch help amit Electrical 17 02-15-2010 03:17 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
