Switch Box / Outlet Photos (with Mid Wire Skining) - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-18-2009, 05:50 PM   #16
Looks good
Should a wire nut be on the twisted grounds?
I actually have quite a lot of metal covers
I keep all my old covers, I use the "ugly" ones in the basement, garage etc where looks is not a concern
Old 02-18-2009, 05:50 PM   #17
Electrician
Originally Posted by jamiedolan View Post
my understanding was that it was good workmanship to make the physical connection with a piece of wire.
Jamie
Naa, thats just a misunderstanding...
chris75 is offline   Reply With Quote
Old 02-18-2009, 05:54 PM   #18
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Originally Posted by Scuba_Dave View Post
Looks good
Thanks.
I used a crimp on connector on the grounds, so no wire nut is required. A mechanical connector is required per code, wire nut, crimp on, wago, etc.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-18-2009, 06:33 PM   #19
Electrician
Rewards Points: 760
Looks good except your GFI is upside down
I am in the opinion if a switch has a ground screw put the ground on it unless someone cut it off during rough in then i will skip it.
darren is offline   Reply With Quote
Old 02-18-2009, 06:34 PM   #20
DIYer
Heh we should stop doing that, every time one of us makes that joke, someone takes it seriously.
Gigs is offline   Reply With Quote
Old 02-18-2009, 06:52 PM   #21
Rewards Points: 150
Send a message via AIM to Bocolo
[quote=darren;232509]Looks good except your GFI is upside down
Actually I have been meaning to ask about this myself. I have seen switches with both the ground up or the ground down. Mostly the ground up I have seen in commercial buildings. I think I read on the code book at one time that some electricians prefer the ground up just in case an object is dropped it would hit the ground portion first. Anyway, what is the correct way? Ground up or ground down? For residential that is. Thanks.
Jamie,
I am not trying to steal your thread, just a quick question while we are on the subject. Your work looks great to me, I am not an electrician but I would rather also ground the outlets. Thanks.
Bocolo is offline   Reply With Quote
Old 02-18-2009, 07:10 PM   #22
Electrician
There is no right or wrong way in residential or commercial, although it may be spec ed in commercial to be ground up.
Old 02-18-2009, 07:39 PM   #23
Rewards Points: 150
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Looking for 3-Way Switch wire Images Evnldr Electrical 10 06-18-2008 09:19 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
trying to wire a light and light switch off of an outlet imphishy Electrical 3 03-16-2005 10:04 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 11:51 PM
