Switch Box Grounding Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2010, 08:00 AM   #1
I have five (5) 12/3 with four (4) switches in a box. This means I have nine (9) ground connections to make (excluding to the box).
Question #1: Since I can only fit a limited amount of ground wires in a wire nut, is the correct way to connect all these ground wires by daisy chain a ground wire from wire nut to wire nut and then to the box ground screw?
Question #2: Is it legal to use multiple ground screws in one (1) box?
If "NO" to question #2, than...
Question #3: Is it leagal to have more than one fork terminal (Ideal Term-a-Nut with Wire Nut, Wire, and Fork Terminal) under the box ground screw? If yes, how many?
Thank you for your help.
MartinD is offline   Reply With Quote
Old 01-26-2010, 08:45 AM   #2
Rewards Points: 1,536
You can have multiple ground screws, each in a suitably tapped hole or as bolt-nut combinations in a metal box.
You can put any number of fork terminals (spade lugs), one crimped to each ground wire or ground pigtail, under a ground screw.
They make little clips that go under one of the hold down screws for the switch or receptacle yoke to achieve the bonding of the device to the box.
I have also done this: take one long bare wire and daisy chain it from the ground screw of one switch or receptacle to the next. (I think this is what they call rabbit-earing.)
Old 01-26-2010, 11:28 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
You can use crimp sleeves to handle that many wires also.
Old 01-26-2010, 02:36 PM   #4
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
Romex quick connects? I've seen ones that can handle 6 wires.
brons2 is offline   Reply With Quote
Old 01-26-2010, 09:47 PM   #5
Registered User
Termite's Avatar
If the box has a ground screw I presume you're using a metal box? If so, you're not required to ground the switches. The metal on the switches if effectively bonded to the box, which is grounded. Switches without green screws/ground terminals are available for this very application. You land your equipment grounding conductor on the box ground screw and you're done.
With a plastic box you've got to ground the switches.
Old 01-26-2010, 10:00 PM   #6
Yes, metal box; from his other thread:
Box-Fill Calculations
ceiling fan works, but light doesn't egildone Electrical 2 09-22-2009 11:20 AM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 09:50 PM
Three way switch questions jerryh3 Electrical 4 11-16-2008 06:09 PM
GFCI switch to control outside outlets billgeo Electrical 14 09-08-2008 11:09 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
