Switch At Beginning Of 3 Light Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2009, 06:12 PM   #1
switch at beginning of 3 light circuit
Three recessed lights on a branch circuit. Switch will be wired at light closest to the power source. Using 12-2 wire. I can't find an explanation of how it's done anywhere.
J Fulks is offline   Reply With Quote
Old 09-29-2009, 06:36 PM   #2
300zx's Avatar
Post
This is for one light for 3 lights just go from one light fixture to the next ....to next...
300zx is offline   Reply With Quote
Old 09-29-2009, 06:46 PM   #3
Thanks 300zx ... that's a good video, but it shows it with power going to the switch first and then from the switch to the light. Power will be coming from the panel to the first light and I'm trying to wire the switch at that same light.
Old 09-29-2009, 07:29 PM   #4
300zx's Avatar
Post
Ok Sorry, You have power going into first light take the power(Black wire from panel) and unhook it at the first light now you have one wire from switch (Black, White, ground) Take the White wire and mark it black hook it to the power(Black from panel) The Ground from switch tie to the grounds in light box The Black wire from switch tie to the Blacks for your lights. At your Switch Ground - Switch with bare wire -Mark your White Black That leaves 2 Blacks to hook to switch. I hope i didn't confuse you to much
Old 09-29-2009, 07:35 PM   #5
300zx's Avatar
Post
Found This site maybe they can explain it better http://www.selfhelpandmore.com/switc...at-fixture.php
Old 09-29-2009, 07:44 PM   #6
You are the man, 300zx! Your explanation was perfect. Thanks buddy!
Old 09-29-2009, 07:52 PM   #7
300zx's Avatar
Post
No problem glad you understood here is another site go down to Step 3 Fig 8 and look at there pic Click on the "Next Step" on the pic and shows you the next step. http://electrical.hardwarestore.com/...ic-switch.aspx
Old 09-30-2009, 02:17 AM   #8
That's is so easy even a caveman could do it! I don't know how you find those resources, but thanks again 300zx!
Installing New Light Switch (NOT REPLACING AN EXSISTING ONE) Light Out on Hillsboro Be Electrical 10 03-11-2012 08:27 PM
Replacing light switch in series wired home - help! kellykate Electrical 6 04-16-2009 06:37 PM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
A simple 2 light --1 switch question? redondo11@msn.com Electrical 7 11-05-2008 08:35 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
