Swimming Pool Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2010, 09:17 AM   #1
Swimming Pool subpanel
Hi,
Purchased a house with in ground pool. Pump and filter located in a small pool house.
200 amp main in the garage with a 30 amp dual breaker feeding a 30 amp subpanel in the garage (separate ground and neutral bus). 8 gauge running from garage to pool house in metal conduit.
There is a four circuit breaker panel in the pool house. 15 amp breaker to hydraulic pool cover and controls. 15 amp breaker to lights and outlets. 15 amp dual breaker to pool pump.
pics at
http://picasaweb.google.com/ted.popp...eat=directlink
Questions:
1. Is the current location of the pool house panel a problem due to access reasons? I plan on moving it because I hate crawling over stuff to get to it.
2. Does the 15 amp dual breaker to the pool pump have to be GFI? Do these motors run on a GFI breaker, or is there too much electrical leakage and the breaker will nuisance trip?
3. Do I need a disconnect outside the pool house? If I have to install a disconnect, I'd like to do it on the right side of the pool house near the fence so I can break the feed and pull new wire to a new panel.
4. If I install a new panel inside the building, should I use an outdoor rated panel to combat corrosion due to humidity and chlorine? Chemicals are stored in the building.
Thanks,
Ted
tedpoppke is offline   Reply With Quote
Old 08-24-2010, 09:22 AM   #2
Additional question - pump is controlled from breaker panel. Per code, does it need a separate switch? Is it OK to operate equipment from a breaker panel?
Old 08-24-2010, 09:53 AM   #3
Where are you located ?
Here a timer is required for a pool pump
I also have a switch near the pump
I don't use the breaker to turn it off & on
Old 08-24-2010, 09:59 AM   #4
NoDak
Here in the Great White North we can only use the pool for a few days a year! I just leave the pump running for the couple of days of "ice out".
On a separate note, I'll probably put an X-10 controller on the pump, so I can start/stop it with a timer or remote.
Tags
access pane , disconnect box , sub panel , swimming pool
swimming pool enclosure grendon Building & Construction 18 02-11-2015 10:30 PM
Pool room subpanel rayt Electrical 3 10-06-2009 01:17 PM
swimming pool shaggysteele Electrical 6 08-04-2009 06:24 PM
Wiring for swimming pool heater and salt system Scooby Electrical 1 06-08-2009 12:59 PM
Swimming Pool Converted To Fish Pond ghall79 General DIY Discussions 6 05-23-2008 12:11 PM
