-   -   swimming pool pump wire (http://www.diychatroom.com/f18/swimming-pool-pump-wire-19563/)
steel 04-06-2008 06:09 PM
I am installing a pool and need help figuring out what kind of wire to use. It will be about 75 feet of wire once it is all said and done. I am using conduit above ground under the deck, but will bury the line once it is clear of the deck.
I will be buying UF wire, but I need to make sure I get the correct gauge. Will 12-2 be good enough to run a pool pump?
I also want to put an outlet on the deck. Am I able to splice off the same wire as the pump or do I need to run a new wire for the outlet? If I can get away with splicing it, do I just splice it inside the outlet box for the pump?
I can get the specs of the pump if they are needed to figure this out. I checked the voltage and it is 115 volts. I'm not sure what else is needed to get this right.
Jim Port 04-06-2008 06:16 PM
Uf wire cannot be used for pool wiring, the ground must be insulated, not covered like UF.
You would need to know the motor load to determine the circuit and wire size.
steel 04-06-2008 06:30 PM
Is there a type of wire I need to get? Does it have a designation (NM, UF,etc.)
Which is the moter load? Keep in mind I am about as ignorant about electricity as can be. I can wire things up but find it incredibly difficult to carry on an intelligent conversation about electricity. I seriously need to know is it's volts, amps, etc. you need to determine the right size.
Is it safe to assume that I do need to run a seperate line for the outlet since the pump gets such a specific wire?
Do I need to ground the wire at the pump with a rod or does it still ground back to the house?
Speedy Petey 04-06-2008 06:56 PM
You need THWN conductors in the conduit.
This is SERIOUSLY NOT conducive to wiring a pool. This is NO place to mess around if you don't know what you are doing, even if you ask questions on an internet message board.
What about the required convenience receptacle?
What about bonding?
What about the twist lock receptacle and in-use cover?
Etc, Etc, Etc..............
LawnGuyLandSparky 04-06-2008 07:04 PM
I'm with Petey on this. Practice your do-it-yourself skills indoors, add a garage outlet or lights in your basement, but for God sakes leave pool wiring to professionals. The codes can be so complicated that even licensed contractors who don't practice the art get it wrong all the time.
chris75 04-06-2008 08:35 PM
I agree, pools are just not a DIY electrical project... You do NOT want to be sued in the unlikely event someone is killed.
