Old 07-21-2009, 09:59 PM   #1
Swimming pool light
I'm an industrial electrician but my next door neighbor called me over 'cause his pool light wasn't working.
1 checked the GFI good
2 removed the light from the pool checked for voltage 12V good.
3 went out and got a new lamp
4 put it back together still did not work
5 removed fixture & lamp checked lamp for continuity good, checked lamp socket for 12V also good.
What am I missing?
480 Sparkie is offline   Reply With Quote
Old 07-21-2009, 10:09 PM   #2
Xtreme DIY'r
Swimming pool light
Screw in lamp or ?
Poor contacts on the bulb/base ?
But you said you tested contacts....
Old 07-21-2009, 10:21 PM   #3
Swimming pool light
What am I missing?
Possibly. There is poor contact between the lamp and socket. (i.e. The lamp may not reach (by a fraction of an inch) all the way in. Or corrosion. Sometimes a little sandpaper might do the trick. Or an Electrically safe Chemical [spray] cleaner. But DEFINITELY NOT WD-40. It's highly flammable. (No matter what) Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
Old 07-21-2009, 11:26 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Swimming pool light
To what did you check voltage? ground or neutral ? assuming this is a ac low voltage light. If you checked to ground you may still have an open neutral.
Having said that 9 times out of ten in my experience it is a problem with the socket connection with the bulb.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
swimming pool light leak... Bet General Discussion 17 09-18-2012 01:13 PM
Replace pool light DONRILEY Electrical 5 07-20-2008 05:51 PM
Pool Pump & Light Wiring Nod Electrical 28 07-15-2008 05:49 PM
Swimming Pool Converted To Fish Pond ghall79 General Discussion 6 05-23-2008 12:11 PM
Swimming Pool Light Broc Electrical 1 08-15-2006 03:23 PM
