#16 |
UAW SKILLED TRADES
Swimming Pool Grounding Issue
I'm not sure what the island building inspector is sourcing to get his information from. I would assume that since he wants this "ocean" ground that all pools on the island have this done. Unfortunately I am not understanding why this is required since it serves no purpose to ground anything. All metal parts required for pools are bonded (connected) in the USA with a #8 copper bonding wire. This simply brings all the metal to the same potential in the event they are subjected to any voltage gradient that may appear in or around the pool. The idea is if the voltage gradient contacts one part of that bonded metal the entire sum of the bonded metal parts comes to the voltage of the gradient. Since there is now no potential difference between any two pieces of metal there will not be a shock hazard.
The driving of the ground rods is rather odd in that it only puts more metal in the ground to became energized in the event of a voltage gradient. But if they are bonded to all the other metal I see nothing detrimental about it. It just seems to be rather redundant and not needed. Maybe the inspector owns the only company on the island that sells ground rods...... I would just give him what he wants I do not see anything dangerous about doing it. JUst be sure you know what is underground before you drive them. Driving a ground rod thru a underground utility lateral can ruin your day. Hope this helped....and hey we were not poking abuse at you this was just some friendly chuckling among ourselves about this "Ocean Ground" it seems comical to us. And don't forget today is April fools day in the US. So we are on guard so to speak to anyone pulling a joke about a term like "OCEAN GROUND". |
#17 |
Thanks Stubbie!
Not only was your answer helpful...it was not condescending. The abuse I referred to was the "you cheapo" shot by LawnGuyLand Sparky...as if I wouldn't try to hire a professional. Bahamas is very protective of it's labour force so I have not been able to hire a fellow American electrician due to immigration regulations. I ask questions to protect myself from matters that do not make sense which here happens often. I understand completely now...thanks! ...just the "inspector" to deal with now! thanks |
#18 |
If you have a ground rod in the earth and rebar in the earth and it is all hooked to earth what is the difference? I know all rebar is bonded but it all ends up at ground correct? I have read a lot and I am not looking for a career in electrical but just trying to understand.
#19 |
Licensed Electrical Cont.
No problem Billy. Grounding and bonding seem simple enough on the surface, but are VERY complex in depth. MANY fellow electricians are still not up on it. Some still think ground rods and other made electrodes have something to do with short circuits and breakers tripping. Some actually think if you stick a ground rod in the ground and connect a wire to it, and there is a short circuit to this wire that the breaker will actually trip.
There are many misconceptions and much misinformation out there. One of the (very) few good changes in the 2008 NEC is the change in some wording and terms with regard to grounding.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#20 | |
Swimming Pool Grounding IssueQuote:
As for the Island electricians and inspector - your "issue" here may have nothing to do with your local workforce. This happens in the USA as well, where an inspector "wants something" but has no basis in code to demand it. They just either think it's required, or, they're looking for a bribe. Find out what your local codes require (from your electrician, and/or call this inspector's supervisors) and ask what the violation would be, (chapter and verse.) |
#21 |
It was a dark and stormy
If you get the Eustace Soares book get the one from 1966 with the long title.
Check your pool between the water and everything else nearby, with a voltmeter. Probably as little as 10mA(300Ω)= 3 vac is dangerous to some people. If it's a phantom voltage it's somewhat less dangerous because the current is limited. |
| Display Modes | |
| swimming pool enclosure | grendon | Building & Construction | 15 | 09-01-2012 03:28 AM |
| Swimming Pool Converted To Fish Pond | ghall79 | General Discussion | 6 | 05-23-2008 12:11 PM |
| Anyone want to take a shot at why #6 to attach antenna ground to breaker? | Piedmont | Electrical | 44 | 01-08-2008 05:11 PM |
| Swimming Pool Water | pilotandy72 | General Discussion | 4 | 07-31-2007 11:04 AM |
