Swimming Pool - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2009, 06:07 PM   #1
swimming pool
has any one heard of a bct test concering bonding of a swimming pool and how deep is it required for a bonding wire to be buried. i built a pool that the county shut down due to lack of inspections there is no bonding wire coming from the pool to the pump i am trying to figure out if there is a way to prove or disprove wheather the wire is under the concrete amy help would be greatly appericated
shaggysteele is offline   Reply With Quote
Old 08-02-2009, 06:26 PM   #2
Electrical Contractor
kbsparky's Avatar
Any concrete poured in or around that pool? Any rebars or wire mesh in there?
You might be looking at renting a jackhammer here ....
-KB
Old 08-02-2009, 06:37 PM   #3
What about renting some ground penetrating radar
This is what happens without a permit
My wire comes out under the slab in the pool cabana
Who poured the concrete?
Old 08-02-2009, 06:50 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
What exactly are you trying to prove or disprove??? Is the bond wire there or not?
Is this a built-in pool, or above ground?
Old 08-02-2009, 08:11 PM   #5
Rewards Points: 2,350
Seems to me, if you built the pool, you would know where the bond wire is and where it comes out. You should be able to walk over to it and point it out.
Old 08-04-2009, 01:41 PM   #6
pool
i did not build the pool it waas built by a pool contractor. they were the ones resp. for the inspections not me. iwas just wondering if anyone had ever heard of a bct test. this pool has been in a lawsuit for 4 years now and i just want my pool fixed if you know what i mean. I know the wire does not come from the pool to the pump ineed to know if anyone knows of a way to tell 100% if there is even a wire up under the concrete thanks for any help
Old 08-04-2009, 06:24 PM   #7
kbsparky's Avatar
Time for the jackhammer.
If you can't find the bonding wire intended for the pump motor, then it probably ain't there.
This is a major safety issue. Without proper bonding and an equipotential plane embedded within the concrete, the pool can be lethal, if sufficient stray voltage becomes present.
Anything from lightning to a downed power line can kill you in an improperly bonded pool.
-KB
swimming pool enclosure grendon Building & Construction 18 02-11-2015 10:30 PM
Wiring for swimming pool heater and salt system Scooby Electrical 1 06-08-2009 12:59 PM
Swimming Pool Converted To Fish Pond ghall79 General DIY Discussions 6 05-23-2008 12:11 PM
Swimming Pool Water pilotandy72 General DIY Discussions 4 07-31-2007 11:04 AM
Swimming Pool Light Broc Electrical 1 08-15-2006 03:23 PM
