Swim Spa Disconnect - Electrical - DIY Chatroom Home Improvement Forum
Old 04-15-2012, 09:41 AM   #1
Swim spa disconnect
Hello
I have a swim spa that I recently purchased about 15 yrs old. Still need to wire in. I am going to install a 100amp sub panel on the back porch. Wire to a disconnect within 5' line of sight from spa with the GFI breaker. Currently I have 4 pumps, lights etc. How do I size the disconnect to handle the load. Aprox 25ft from sub panel to disconnect. Will be using a Ng boiler instead of Kw heater. Any suggestions would help. Thanks
buehler is offline   Reply With Quote
Old 04-15-2012, 10:31 AM   #2
Rewards Points: 246
Find the specifications on the tub or inside the connection box. You/we need to know what the manufacturer requires. Find the nameplate/tag and someone can help.
Old 04-15-2012, 10:37 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
As per the 2011 NEC, the disconnect CANNOT be within 5' of the inside wall of the hot tub.
With that said, wiring a hot tub is not a good DIY project. There are a number of code issues that you will have to adhere to. Items such as metal type siding, downspouts, gutters. Also, there may be requirements as to GFI protecting existing lights and outlets within a certain distance from the hot tub.
By the very nature of pools and hot tubs, I would not recommend a homeowner taking on the wiring of such items.
Fused disconnect or unfused, motor is fed from breaker... Do It Right Electrical 17 03-19-2011 12:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
30A Air Conditioner Disconnect JPWMU Electrical 6 04-19-2010 03:55 PM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 01:36 PM
Main disconnect box before service panel Cellomangler Electrical 4 02-04-2008 07:43 AM
