Swapping Recessed Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 07:39 AM   #1
Just call me Andrew
Rewards Points: 1,020
Swapping recessed lights
Some fiends of mine have a room with 8 recessed lights, above which is an attic. In the winter, they can feel cold air coming in from each light fixture. Is there a way to "convert" fromt heir old non-ic non-airtight cans to IC/Airtight? Or do we just need to replace the lights?
Andrew
secutanudu is offline   Reply With Quote
Old 06-19-2011, 09:32 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
See if you can find some air-tight trims that fit those cans. Big-box stores carry some.
Kyle
Recessed lights in kitchen - need advice rfranco1 Electrical 3 01-29-2011 07:29 PM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 01:10 PM
Fire Hazard worry on Low wattage recessed lights usng 50w halogen bulbs jomieblumreich Electrical 7 08-15-2009 04:20 PM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 10:11 AM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
