Swamp Cooler Pops GFCI - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 12:20 AM   #31
" Euro " electrician
frenchelectrican's Avatar
If you going to read the amps on the motor load as I say before use the clamp on that is the safest one you can use and do not use the multimeter for reading current more than just a amp or two the most otherwise it can wreck it.
The motor starting current will wreck the mulitmeter pretty fast.
The clamp on ampmeter I am not sure what they cost but IIRC it will be about 50 to 80 Euros {Dollars } unless you ask someone whom have one then they can loan ya one { throw in a case of beer or soda useally do the trick }
Merci.
Marc
Old 09-03-2010, 12:23 AM   #32
Merci.
Marc
Ok thanks for that. I'll ask around and see. Maybe the tool rental place here in town has one if all else fails.
broken68 is offline   Reply With Quote
Old 09-03-2010, 06:59 AM   #33
Rewards Points: 6,652
I meant current drain, but most people understand the term voltage better, because they do not realize that other factors are in play to get their lights lit, etc.
Old 09-03-2010, 09:55 AM   #34
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Broken68
You mention that sometimes it takes 5 minutes for the gfci to trip...? If you have a fault to ground or neutral or hot the trip is usually immediate. A winding insulation short/leakage I think would be immediate not in 5 minutes or so.... are you sure there isn't moisture dripping or forming on an electrical connection after it operates for awhile? the fact it only trips on HI should narrow down to pump or motor or moisture. The motor has a high speed winding or it may be the pump that starts automatically when high is selected ...not sure. The fact that it trips the gfci indicates a safety issue as current is going somewhere it shouldn't. Motors for these things are required to not have so much leakage that they trip a gfci unless they are faulty like a bad winding or something. IMO operating it on gfci is not a bad idea.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 09-03-2010, 10:18 AM   #35
UAW SKILLED TRADES
Stubbie's Avatar
No problem Greg just wasn't sure where you were going with the term voltage.
Stubbie
Old 09-03-2010, 05:07 PM   #36
Originally Posted by Stubbie View Post
Broken68
Well it started off being instantly once the cooler was switched to high cool or high vent. I changed out the breaker at the box and now it runs roughly 5 mins before it pops the gfci. I'm still looking for a clamp on style ammeter. but I've got the word out.
Old 09-03-2010, 05:46 PM   #37
They should have them at Lowes or Home Depot in the Electrical section with the tools.
Old 09-03-2010, 06:42 PM   #38
yeah just trying to find one local. Our nearest Lowe's and Home Depot is an hour drive away one way.
Old 09-28-2010, 08:00 PM   #39
Figured it out!
Well I have had the exact same problem with my unit I just put together. I got a old swamp cooler from my father in law and totally gutted it out and put new everything into the box. I have a 1 hp motor running the unit. After getting everything set up and running high cool would work fine for me but as soon as I switched it to low cool it would trip my gfi in garage! The strange thing is that sometimes it would do it right away and other times it would take 30 min. or so. I checked the amps my cooler was running and that part seemed fine. I went ahead and took out my gfi unit in garage I have heard that they do go bad sometimes if they trip a lot. I bought a 20 amp up stream and a 20 amp down stream gfi installed it and have had no problem since! The 15 amp down stream was the issue I beleive.
josh86442 is offline   Reply With Quote
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Removing swamp cooler control Pharmjae Electrical 3 02-10-2010 03:36 PM
Swamp cooler vents Summiteer HVAC 4 02-04-2010 04:59 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
Swamp Cooler vs AC mtcone HVAC 3 05-19-2008 02:43 PM
