Swag Lamp - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2008, 01:21 PM   #1
Question
Swag Lamp
Can I cut the plug off a swag lamp and hardwire the lamp to the existing outlet box for the old light?
dwight.stephens@scc.virgi is offline   Reply With Quote
Old 04-29-2008, 02:44 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Yes, what you will create is no different than a standard light fixture intended to be hard wired. Assuming you use the proper strain relief and chaffing protection that a new fixture would provide (ie; reuse from old fixture).
Old 04-29-2008, 03:42 PM   #3
Registered User
Termite's Avatar
Not likely a good idea. If the lamp came with a cord and plug, chances are that it is not UL listed to be installed hard-wired. Will it work? Yes. Probably not a good idea however.
Old 04-29-2008, 09:04 PM   #4
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
To repeat what thekctermite said:
I doubt that the UL listing (or other agency) includes cutting off the plug and hard wiring it into a box. The electric code says all equipment must be used and installed per it's listing. Your homeowners insurance probably insists all wiring comply with the electric code.
John
jrclen is offline   Reply With Quote
electric wiring for fluorescent lamp toronbolo Electrical 3 03-24-2008 12:16 PM
Using a european lamp in the States mattlima Electrical 3 03-16-2008 08:12 PM
Electric receptacle in lamp post and flood light not working th31 Electrical 7 12-13-2007 07:46 AM
Direct-wire a swag lamp? chathamsq Electrical 1 07-02-2007 12:46 PM
Do canned lights overheat? Not Sure Electrical 14 12-27-2006 07:44 AM
