SWA Cable, What Size To Use? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-12-2009, 11:55 AM   #1
Post
SWA cable, what size to use?
Hi
I am looking at running a Swa cable in to a field to connect up to 5 caravan power outlets each one being limited to 15 amps. The cable run is going to be 140 meters. Taking in to account voltage drop and the load i am looking to find out what size cable i should run?
paul1978 is offline   Reply With Quote
Old 11-12-2009, 05:20 PM   #2
Electrical Contractor
kbsparky's Avatar
From the terminology used, I'd wager a guess that you are in Australia?
-KB
Old 11-13-2009, 04:53 AM   #3
No im in the uk.
Old 11-13-2009, 02:25 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
HI Paul
This is primarily a USA and Canada site. Your codes are much different than ours and your mains supply is different. We could likely determine the wire size for you but it would be far better for you to find a UK based electrical forum that can steer you in the right direction both for code compliance and safety. What your doing is basically the same thing we do here for RV's (caravans) park pedestals.... to you those are called bollards. If you want a link to a good UK forum I can help you with that.....
Stubbie
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 11-13-2009, 02:39 PM   #5
15A at 240! those must be rockin caravans!!!
Salem747 is offline   Reply With Quote
Old 11-13-2009, 02:41 PM   #6
ok thanks stubbie
Old 11-13-2009, 08:06 PM   #7
UAW SKILLED TRADES
Stubbie's Avatar
This one is pretty good
http://www.askthetrades.co.uk/cgi-bi...B.pl?board=Diy
Stubbie
Old 11-14-2009, 01:52 AM   #8
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by paul1978 View Post
Hi
I can help some of the details due I live in France so I am famauir with some of the UK codes
For the Caravan power points the RCD is mantory useage.
so for conductor size from the main customer unit to centre point you will need 70mm˛ if monophase otherwise with triphase the conductor size will be far much smaller { I rather leave in monophase format for safety issue To other readers keep in your mind the European system typically run 230-240 volt line to netual }{ if you have triphase supply let me know that will change the figures a bit and you will need secondary load centre as well }
But you will need a large termation box to reduce the conductor size to fit in the breaker and power point recetpale and it have to be wet location repceptale { not the same fashion as USA/Cananda is }
That conductor size I did based keep the voltage drop below 3% but if you can have little more voltage drop you can use 50mm˛ conductor SWA cable if you have to but all it depending if you have breaker or fuse at the receptale location or not.
If not let me know I will make a drawing how to connect in proper foramat.
Merci,
Marc
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
Cable Size for Sub Panel vs chart jamiedolan Electrical 5 11-09-2008 02:30 PM
Cable size advise needed makulos Electrical 3 10-22-2008 12:13 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
