Suspect Grounding In Rental Home? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2007, 11:30 AM   #1
Suspect grounding in rental home?
I'm preparing to move into a home I've rented and have found that some (okay, most) of the wiring has issues.
The home has a mix of two- and three-prong outlets. Only a minority of the three-prong outlets show ~120V from hot to ground when tested with a multimeter. Most of them show ~12-18V from hot to ground. They all read as expected from hot to neutral, ~120V. (Actually a little higher, ~124V.)
An outlet currently used for the washing machine is among the outlets with a low hot-to-ground reading. If I check from hot to a nearby water pipe, I get ~120V.
As a second issue, one of the outlets in the master bedroom is showing voltage from neutral to ground. Forget the exact reading but it was ~16V. It also has low hot to ground.
Could someone with more experience elaborate on the safety and fire hazards these readings could indicate?
Beren is offline   Reply With Quote
Old 04-27-2007, 04:20 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
There is no real fire danger, just someone went in and installed 3-prong receptacles where no ground was present.
Tell the landlord/owner. DO NOT attempt to do ANYTHING about this yourself.
Old 04-27-2007, 05:04 PM   #3
I thought that might be the issue, but if it were, wouldn't I see ~0V from hot to ground?
I've notified the owner's agent, who is going to have an electrician take a look at things next week.
Old 04-27-2007, 05:34 PM   #4
No, not at all. There are several factors that would give you erroneous readings, especially using a digital multi-meter.
Old 04-27-2007, 11:42 PM   #5
Interesting. As time allows, would you elaborate? I'm going to let the professionals handle this, but I'm curious what would cause misleading readings with the digital multimeter.
Old 04-28-2007, 06:28 AM   #6
Beren, here is a good place to start.
http://www.allaboutcircuits.com/vol_1/index.html
Master Electrician
jwhite is offline   Reply With Quote
Old 04-28-2007, 06:50 AM   #7
Here's another:
http://en.wikipedia.org/wiki/Phantom_voltage
Old 04-28-2007, 10:52 AM   #8
Aha! Thanks for the links. So if I put a lamp somewhere on that circuit and retest at another outlet, chances are I'd read ~0V from hot to ground if my original readings were phantom voltage, right?
Old 04-28-2007, 11:01 AM   #9
I know for sure that the test you suggest will work if checking hot to neutral on a dead circut. Sometimes I just use a resistor.
Since the ground is not hooked up to the neutal of the lamp, I am not sure what the results would be. If you try, let us know.
If you hook a test light up to hot and ground, then you would get zero.
Master Electrician
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
